Thread: have spark and fuel pressure. no start
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: have spark and fuel pressure. no start
    GT Level Member m17davis's Avatar
    Orland Park, IL
    Nope. I had one for the map and maf but I fixed both of them
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #22 Re: have spark and fuel pressure. no start
    Orland Park, IL
    well i dont have injector pulse! now i have to figure out what gives it a beat. ive had the icm tested and it passed. so i just bought a crankshaft pos sensor. thats all i can think of. but the wierd thing is that i have spark.?
  3. #23 Re: have spark and fuel pressure. no start
    i think crank is spark and cam is fuel, for what they control.
  4. #24 Re: have spark and fuel pressure. no start
    Orland Park, IL
    camshaft sensor replaced..... no start
  5. #25 Re: have spark and fuel pressure. no start
    Nov 2011
    south carolina
    What year is this car?
  6. #26 Re: have spark and fuel pressure. no start
    With ignition on, check for power at the injector plug.
    The pcm supplies ground. First at key on, it primes the pump and cylinders which gives you a momentary injector pulse, turns the injectors off until the motor is running.
  7. #27 Re: have spark and fuel pressure. no start
    Orland Park, IL
    It's a 2000 gtp. I have power at the injector plug. Just not pulse. I replaced the cam sensor. And i scanned it and got a engine speed reading. So the crank sensor works?
  8. #28 Re: have spark and fuel pressure. no start
    SE Level Member jaked1985's Avatar
    Jan 2012
    West Union, Iowa, United States
    Bad pcm?
  9. #29 Re: have spark and fuel pressure. no start
    Orland Park, IL
    I don't think so. I put the stock pcm on and no change
  10. #30 Re: have spark and fuel pressure. no start
    Nov 2011
    south carolina
    No codes?
    Slowly go through your exhaust repair in your head, while looking at the individual items as you remember them. It sounds like something not assembled correctly. Check your grounds, did you leave a nut/bolt loose? Theres one on a stud at the transmission, theres one under the icm. Is there a plug not plugged in all the way and you disturbed it while working on the car? etc? Sometimes a person can cause problems that just won't ever happen under normal circumstances and these problems can throw normal trouble shooting procedures out the window. Think outside the box now, take your time and recreate every step of the work you performed.
  11. #31 Re: have spark and fuel pressure. no start
    Orland Park, IL
    Alright. Thanks. No codes. I'm confused cause all I took off was the throttle body plug wires and dogbones. But ill take another look.
  12. #32 Re: have spark and fuel pressure. no start
    Orland Park, IL
    Well I replaced the crank sensor and no start. Does anyone know how I could test the wiring system to find out why I have no pulse?
  13. #33 Re: have spark and fuel pressure. no start
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    Did anyone ever figure this issue out?, bc I am about to be looking into almost the same exact situation.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  14. #34 Re: have spark and fuel pressure. no start
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    get a noid tester and plug it into one injector connecter. try to start car if the tester blinks you have pulse if it stays lit you have a wiring or circuit issue
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  15. #35 Re: have spark and fuel pressure. no start
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Could it have something to do with the anti-theft system?
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  16. #36 Re: have spark and fuel pressure. no start
    Dec 2012
    Illinois
    There is a chance the fuel pump is going bad, but taking it's sweet time to do it. I've had (and seen) cars that won't start, and then can't reproduce the problem for weeks at the time where you could hear the fuel pump kick on, but the car would die shortly after. And also cars where the fuel pump would crank the engine, but not pump fuel after it started.
  17. #37 Re: have spark and fuel pressure. no start
    Orland Park, IL
    this was an extremely easy fix that took about 2 mintues. one of the wires go to a sensor on the tb was cut some how. I couldn't believe it when I saw it
  1. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  2. Car won't start << No Spark>> please help!
    By Pipeliner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2011, 08:40 AM
  3. Low Fuel Pressure on first start up. HELP!!
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-31-2010, 11:43 AM
  4. HELP car won't start, got fuel, got spark, got air?
    By bezemom in forum General Tech Discussion
    Last Post: 05-29-2009, 02:19 PM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
