Thread: battery dies overnight please help
Results 1 to 8 of 8
  1. #1 battery dies overnight please help
    SE Level Member orangecreme's Avatar
    sterling heights,MI
    I have a problem
    My key is stuck in the ignition and the wheel does not lock.
    My battery dies allot overnight.
    The only thing that stays on is the Indicator light for shifter on dash.
    Could this be the cause of the battery dying?
    alternator and battery are good.
  2. #2 Re: battery dies overnight please help
    under the steering coloum there is a small tab you can remove, then stick a screw driver up there and it will push up a white tab that will release the key from the ignition.
    and if you battery keeps dying over night, either the battery is bad or the alternator is not doing its job charging the system.
  3. #3 Re: battery dies overnight please help
    SE Level Member GPmanter's Avatar
    Nov 2011
    Reynoldsburg, Oh
    There could be a parasitic draw on the battery. What normally stays on is such a small voltage that it shouldn't drain overnight. If you connect a test light in series with the positive battery cable & start pulling fuses you can see what causes the light to go out. You can also unplug the alternator to see if that is causing a big drain. First things first, have that battery & alternator checked to see if either is bad.
  4. #4 Re: battery dies overnight please help
    Fargo, ND
    Adding on to that, if you take a straw (yes, a drinking straw), and cut off about an inch, you will be able to stick it on that small tab you just removed, and put it back in the steering column. It is a cheap workaround for the lock solenoid in your steering column which appears to have failed. I used to have the same problem you are having about 4 years ago. Haven't had a stuck key since though, ever since I used the straw method
  5. #5 Re: battery dies overnight please help
    GT Level Member nicks98gtp's Avatar
    michigan
    another way to check for any parasitic draw, disconnect your neg. battery cable, and place an ammeter in series (one end on the negative cable, and the other end on the negative terminal on the battery itself) and check your reading. not exactly sure on the spec but it should be a very low reading, if you have anything over .05 amps start pullign fuses until that number drops
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  6. #6 Re: battery dies overnight please help
    sterling heights,MI
    the straw worked. thanks
    should there be any power going to the fuses under the hood?
  7. #7 Re: battery dies overnight please help
    Fargo, ND
    Awesome, glad to hear it worked for ya.
  8. #8 Re: battery dies overnight please help
    sterling heights,MI
    well my battery stopped dying now that the key is out.
    now to find my washer pump wire
  1. new battery? maybe?
    By tcafego in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 11:48 PM
  2. Transmission won't shift into drive after sitting overnight
    By Toadster in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 06-09-2011, 05:52 PM
  3. Getting a car battery
    By Warbeaver in forum General Tech Discussion
    Last Post: 05-31-2010, 06:11 AM
  4. New alternator, new battery, car still dies.
    By m0ng00se in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2010, 12:48 AM
  5. battery help!
    By DDPeppa in forum General Tech Discussion
    Last Post: 08-23-2009, 11:49 PM
