Thread: Need a couple of ideas to get an MPS off...
Results 1 to 20 of 21
  1. #1 Need a couple of ideas to get an MPS off...
    Jan 2009
    Tallahassee, FL
    I'm trying to pull off an MPS with a Smoothflow puller. A little history, when. I got my MPS and threw it on (bought it used) with the bolts I got with it they all eventually either stripped out or snapped off. That left me in the predicament to get the bolts to retread, I got 3 of the 6 to work out, they've been holding up fine until I tried to pull the hub off. One of the bolts stripped so I'm stuck with it still attached. What I'm trying to do is put on a stock pulley since I'm going top swapped basically.
    Anyone got any ideas to get this off? I was thinking of waiting till I pull off the blower until so I could drill/thread the holes for all the bolts to get it off. Last resort would be to cut it off...
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: Need a couple of ideas to get an MPS off...
    Indianapolis
    These worked good for me when I was trying to get out a stripped bolt
    Sears: Online department store featuring appliances, tools, fitness equipment and more
  3. #3 Re: Need a couple of ideas to get an MPS off...
    Omaha, NE
    Do you need/ have a backing plate for hub removal?
  4. #4 Re: Need a couple of ideas to get an MPS off...
    Waukesha, WI
    BFH
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  5. #5 Re: Need a couple of ideas to get an MPS off...
    Omaha, NE
    Quote Originally Posted by redlinepontiac View Post
    BFH
    BFH could bend the snout causing permafail.
  6. #6 Re: Need a couple of ideas to get an MPS off...
    Waukesha, WI
    meh.
    RayRay
    92 Turbo miata
    02 lexus is300
    Jan 2009
    Tallahassee, FL
    No backing plate. I was just thinking about waiting and cutting it off...
    77 Morris Garage B
  8. #8 Re: Need a couple of ideas to get an MPS off...
    SE Level Member justin10morrissey's Avatar
    Nov 2011
    Missouri
    you could leave it on and get a 3.8 pulley for the mps re thread those bolts and still be able to drop pulleys in the future. just a suggestion
    Jan 2009
    Tallahassee, FL
    That's true, I'm not planning on dropping though. The stock pulley is free lol
    77 Morris Garage B
  10. #10 Re: Need a couple of ideas to get an MPS off...
    Feb 2008
    Why couldn't you just rent/buy a 3 jaw pulley puller and pull it off that way? Shouldn't do any damage to the shaft, and if you aren't reusing the MPS and it's all stripped out anyway there is nothing to worry about. It probably won't even damage it though. Just hope the guy who put it on put some anti-seize on when he pressed the hub on
  11. #11 Re: Need a couple of ideas to get an MPS off...
    Jan 2009
    Tallahassee, FL
    I put it on, no antiseize lol
    77 Morris Garage B
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Make your own backer plate... Just run down to your local metal recycler, dig through their **** for a decently thick piece of aluminum or steel. I got a nice 15"x15"x1/4" piece of aluminum for around $6 been making block off plates and bunches of other stuff out of it for almost 2 years now, got 1/4 of it left.
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  13. #13 Re: Need a couple of ideas to get an MPS off...
    Feb 2008
    Quote Originally Posted by Sandman View Post
    Meh, I'd still give it a shot, it really can't hurt anything. It's kind of your only option!
  14. #14 Re: Need a couple of ideas to get an MPS off...
    Feb 2010
    Oklahoma City, OK
    If you don't wanna make your own just buy this one. Job done, have a useful tool for next time or to bail a friend out.
    http://intense-racing.com/Merchant2/...y_Code=3800_BE
  15. #15 Re: Need a couple of ideas to get an MPS off...
    See if someone on here will let you borrow one?
  16. #16 Re: Need a couple of ideas to get an MPS off...
    Waukesha, WI
    call the A team
    RayRay
    92 Turbo miata
    02 lexus is300
  17. #17 Re: Need a couple of ideas to get an MPS off...
    Jan 2009
    Tallahassee, FL
    A backing plate? I made on at work out of some 1/4" plate we had laying around.
    77 Morris Garage B
    Feb 2010
    Oklahoma City, OK
    Making your own **** FTW!!!!
  19. #19 Re: Need a couple of ideas to get an MPS off...
    I meant the whole puller...but as long as you got it, I guess that works.
  20. #20 Re: Need a couple of ideas to get an MPS off...
    Jan 2009
    Tallahassee, FL
    I bought a puller lol
    77 Morris Garage B
  1. If I had a couple G's..
    By JGSuperCharged in forum Off Topic Discussion
    Last Post: 08-12-2011, 12:22 AM
  2. tattoo ideas for my cast! post your ideas!
    By putskijr in forum Off Topic Discussion
    Last Post: 07-11-2010, 04:53 PM
  3. Couple ?s
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 04-15-2010, 12:14 AM
  4. couple of questions, couple of issues
    By zero in forum General Tech Discussion
    Last Post: 12-30-2009, 04:48 PM
  5. Need a couple PN's.....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 01-02-2008, 09:55 AM
