under the steering coloum there is a small tab you can remove, then stick a screw driver up there and it will push up a white tab that will release the key from the ignition.
and if you battery keeps dying over night, either the battery is bad or the alternator is not doing its job charging the system.
Adding on to that, if you take a straw (yes, a drinking straw), and cut off about an inch, you will be able to stick it on that small tab you just removed, and put it back in the steering column. It is a cheap workaround for the lock solenoid in your steering column which appears to have failed. I used to have the same problem you are having about 4 years ago. Haven't had a stuck key since though, ever since I used the straw method
