well now that its finally done raining i can get out and look at the car, i noticed the other day when i was changing the valve cover grommets, that the block between the head and the block on the back side where its leaking from looked wet. this is after being inside the garage. Only reason i was thinking head gaskets is theyre not factory, they were repalced when the motor was rebuilt ~11k miles ago. You'd think they would be fine, but my valve cover grommets with the same mileage from the same distributor just started leaking also. Im hoping that the gaskets arent bad, but ill report back tommorow with any findings. It doesnt seem to blow any smoke while its running, which I thought they did if the head gaskets went.
