Thread: Leaking Coolant
Results 1 to 7 of 7
  1. #1 Leaking Coolant
    Jul 2010
    El Mirage Az
    My car is leaking coolant on the drivers side near the coolant tank, not sure exactly where it is coming from but it only leaks after shut down. I just flushed it, (it was leaking before I flushed it) could it be i just overfilled it because the past couple days it been HOT out (like 120F) so Ive been adding coolant as needed or could it be from them spring type hoses clamps? or even something else? Any answer helps.
  2. #2 Re: Leaking Coolant
    Charles City, IA
    It is leaking out of the tank?
    SMGPFC Two Nipple General
  3. #3 Re: Leaking Coolant
    Jul 2010
    El Mirage Az
    Im not sure, its in that area but, I havent had that much time to look
  4. #4 Re: Leaking Coolant
    Dec 2008
    Lawndale, CA
    Check the coolant elbows by the alternator, the lower intake manifold and the water pump. The first two seem very likely.
  5. #5 Re: Leaking Coolant
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Quote Originally Posted by nav View Post
    Im confused.. "DRIVER SIDE" next to the coolant tank? Do you have a 97? If not your coolant overflow tank is on the passenger side. IF thats the case see above post and check your elbows.
    Grand Prix Net: Cooling Elbow Pictures remove / install walkthrough
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  6. #6 Re: Leaking Coolant
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    change your radiator cap. yes it must be a 97 with the coolant recovery tank on the drivers side.
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  7. #7 Re: Leaking Coolant
    Jul 2010
    El Mirage Az
    yeah its a 97, i just replaced the radiator cap about a week ago.
  1. Leaking Coolant
    By nav in forum Introductions/Noob Questions
    Last Post: 07-19-2010, 03:55 AM
  2. leaking coolant
    By pacothetaco in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-04-2010, 11:25 AM
  3. Think im leaking coolant
    By blackgpgt in forum General Tech Discussion
    Last Post: 02-14-2010, 03:56 PM
  4. Leaking coolant.
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-16-2010, 12:21 PM
  5. leaking coolant
    By rdicarlo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-19-2008, 10:04 AM
