Thread: aftermarket boost guage?
Results 1 to 20 of 22
  1. #1 aftermarket boost guage?
    SE Level Member reallyfast1's Avatar
    Aug 2008
    CAMBRIDGE,ONTARIO,CANADA
    new to supercharged engines!! k so i just got a 2006 grand prix GT and it is supercharged !! the HUD shows boost but not in PSI!! so i just got a boost guage and i was wondering how to install it on this engine?? its the 3.8l V6 S/C series 3 so does anyone know how to hook up an aftermarket boost guage??? and also does anyone know what PSI this engine runs stock???
  2. #2 Re: aftermarket boost guage?
    Oklahoma
    What gauge did you get? Most will have a vacuum line that runs from the gauge to a vacuum line on the engine. Typically there is a connection on the passenger side of the LIM that most will use a T to connect to. Then you just have to hook up the power for the lighting in the gauge.
    I think most stock engines will run about 7 - 8 psi if I remember correctly.
  3. #3 Re: aftermarket boost guage?
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    BTW... LIM is lower intake manifold.... I ran mine off the vacuum line in front of the blower....
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  4. #4 Re: aftermarket boost guage?
    Aug 2008
    cool thx for the info!! BTW i got a PROSPORT smoke series boost guage!! its lights up blue!! but its gonna look a bit off with the pure orange from the normal guages!! will post some pix somtime soon!!
  5. #5 Re: aftermarket boost guage?
    Oklahoma
    I'll be looking forward to the pics.
  6. #6 Re: aftermarket boost guage?
    Donating Users blowfishRus6's Avatar
    g.a.
    close scotty but i belive stock is 6 psi
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: aftermarket boost guage?
    Barksdale AFB, LA
    Quote Originally Posted by reallyfast1 View Post
    I love my ProSport fuel pressure gauge.
    http://img.photobucket.com/albums/v3...2/DSC02418.jpg
    2009 Subaru Impreza WRX STI
  8. #8 Re: aftermarket boost guage?
    Oklahoma
    A good close up of that gauge and your Aeroforce would probably make a good screen saver picture.
  9. #9 Re: aftermarket boost guage?
    Barksdale AFB, LA
    Oh really...? I'll see what I can come up with.
    Day or night? Seeing how I have an all blue interior...
  10. #10 Re: aftermarket boost guage?
    TDCRacing
    Guest
    I'm thinking day.
  11. #11 Re: aftermarket boost guage?
    Oklahoma
    I dunno, it depends on how good of a photographer you are. If you understand depth of field and can sufficiently blur out the background, then day shots would be nice. It would be ideal if you could get some pictures of the aeroforce in action measuring some parameters. Night pictures would be cool too I think.
    I would think to sufficiently blur the back ground during a day shot you would need an aperture of like f/4 or larger (larger being like f/2.8 or something along those lines). There a several variables that affect the depth of field, so the f/4 would be just a starting point you may need to go to a smaller aperture like f/5.6 depending on what kind of camera you are using. If none of this makes sense, then do the best you can.
  12. #12 Re: aftermarket boost guage?
    Banned
    Wichita Falls, Texas
    Hmmm... not to steal any of Sabrewing's thunder, but I may try what your talking about in a few hours Syn. Considering it'll still be dark out and I have the blue Aeroforce as well.
  13. #13 Re: aftermarket boost guage?
    Aug 2008
    Quote Originally Posted by Sabrewings View Post
    yup mine is the exact same color too but mine is boost!!
  14. #14 Re: aftermarket boost guage?
    GTX Level Member Freebeer187's Avatar
    Bartlett, IL
    Gauges are cool
    How To: E-Brake Pwn
    2001 GTP. D/S Rotors * Custom Intake * DHP PCM *
    Looking For - 3" in DP with Cat. PM me if selling
  15. #15 Re: aftermarket boost guage?
    utah
    Is this the same way to hook it up to a series
    2?
  16. #16 Re: aftermarket boost guage?
    Dead thread ftw
  17. #17 Re: aftermarket boost guage?
    Donating Users kfish's Avatar
    Ohio
    yes, it is
  18. #18 Re: aftermarket boost guage?
    Jersey
    COOL! and old thread!!!
    to answer bluevets question, hook it up into the vacuum line that goes into the map sensor.
    16' wrx sti- stock
  19. #19 Re: aftermarket boost guage?
    Better be looking into a bottom end if you follow the mod list in your sig too.
  20. #20 Re: aftermarket boost guage?
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Agreed. You need those headers to be safe on your 3.4 setup, no way to run a 3.0. You'd need extensive amount of mods for that. And you've got to be knocking with that list of mods, my mods (not trying to be holier than thou) are what it takes to run a 3.4 setup with 0* knock. But then again every car is different, whatever works.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  1. More boost?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 07-25-2008, 12:33 AM
  2. Boost Bypass mod
    By BADAZGTP in forum General Tech Discussion
    Last Post: 05-30-2008, 11:49 AM
  3. Boost Bypass Mod????
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2008, 11:04 AM
  4. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
