Thread: l67 buildup
Results 1 to 13 of 13
  1. #1 l67 buildup
    texas
    going to be building up a motor for my car need some suggestions,
    here is what my plans are so far.
    -05 N/A series II short block assembly
    -stock l67 heads-intake-
    -ported blower.
    i plan on doing a cam of some-sort and then the rockers as well,
    what rockers and cam combo would be best for a mildly built l67? not looking to set any records but i would like to have around or so at the crank, would love that number to the wheels but i dont want to have to get crazy with the motor.
  2. #2 Re: l67 buildup
    Apr 2009
    stockton ca
    use l32 heads instead of l67
    I wouldnt recomend cam+rockers
    headers (ssac,speed daddy)
    tune(dhp,intense,overkill,Dyno custom)
    cam for mild id say s1x intense cam or xp zzp
    105# springs
    Head studs and reusable rocker bolts
    open cone intake
    3.4 pulley to start drop to a smaller pulley later when all the bugs are worked out and youve scanned for kr
    Ported blower Theres a few people on here that do good work
  3. #3 Re: l67 buildup
    texas
    what would i gain from the l32 heads? and wouldnt i have to get a custom intake for the n/a heads for the right location on the injectors?
  4. #4 Re: l67 buildup
    Apr 2009
    stockton ca
    l32 are the newer s/c 3.8 heads and come with either larger intake or exhaust valves cant remember wich
  5. #5 Re: l67 buildup
    texas
    oh ok well in that case no problem i have a set of those laying around i confused those for the others, to many l3x motors
  6. #6 Re: l67 buildup
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The valves are larger, but the valve seats aren't. The gains are marginal to non existant. Just use the L67 heads if you've got them.
    2001 Buick Regal LS - Almost Stock
  7. #7 Re: l67 buildup
    texas
    currently the ones that i have are the l32 heads, will have a set of l36? heads that come with the n/a motor, the l32 heads in storage and then the l67 heads that are currently on the car.
  8. #8 Re: l67 buildup
    QCA, IA
    My point is that you can use wither L32 or L67 heads, it really doesn't matter. They're even the same casting. L36 would change things up because of the injector issue like you mentioned.
  9. #9 Re: l67 buildup
    Apr 2009
    stockton ca
    if you have the l32 heads no harm in useing them
    make sure to have a valve job done on them
    and your in bussiness
  10. #10 Re: l67 buildup
    texas
    yeah im sure i would just have them freshened up the car only had around 36K on it when it was wrecked, but ill have a machine shop do a valve job and install the new springs
  11. #11 Re: l67 buildup
    Should have them do the exhaust ports too
  12. #12 Re: l67 buildup
    texas
    i was looking at intense heads last night and correct me where im wrong but the only difference between stock and stage 4 is....
    -amount of porting
    -upgraded springs
    -manley valves.
    if that is the case would i be better of having my l32 heads hogged out and the reassembled with the springs and valves?
  13. #13 Re: l67 buildup
    Quote Originally Posted by butt86 View Post
    -amount of porting
    -upgraded springs
    -manley valves.
    The work a local machine shop can do blows the intense heads out of the water for the price. I got a good deal on mine but Igot my heads done for under $600. Full port on both the intake and exhaust side, valve job, springs/retainers/seals/locks/valves installed. Go look in the bluegtp91's build thread for pics of everything. IIRC they are on like page 9 or something.
  1. M90 Pump gas Buildup!
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2009, 01:31 AM
  2. dirt buildup so fast
    By tod1d in forum Visual/Body Modifications
    Last Post: 08-07-2008, 01:23 PM
