What gauge did you get? Most will have a vacuum line that runs from the gauge to a vacuum line on the engine. Typically there is a connection on the passenger side of the LIM that most will use a T to connect to. Then you just have to hook up the power for the lighting in the gauge.
I think most stock engines will run about 7 - 8 psi if I remember correctly.
