Thread: Car wont start need help erratic rpm
Results 21 to 40 of 41
  1. #21 Re: Car wont start need help erratic rpm
    SE Level Member justin10morrissey's Avatar
    Nov 2011
    Missouri
    Quote Originally Posted by coolone View Post
    Was there an issue over heating engine prior to fixing or replacing pump? Just curious... Crank positioning sensor is sensitive to high heat temps... Not as common a problem but It's something I ran into with my old GP... Just sayin. But others might be able to chime in better on this suggestion? But if it goes, you will see erratic rpm's and even the engine shutting down and not starting cause the computer doesn't know the actual rpms of crank and firing position, etc...
    Hope you find solution!
    it wasnt really overheating just lost enough coolant to cause steam under the hood but was repaired before it ever overheated
  2. #22 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    changing out crank position sensor. its a possibilitiy that one of the razor blades i was using to clean off the gasket from the water pump had fallen behind the crank pulley and i know there is a magnet in there which could have ruined the sensor im gunna have fun getting that crank pulley off
  3. #23 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    changed out crank position sensor the old one was ruined but still not getting any spark...icm? or does the computer need to be relearned for the cps or when the throttle body is taken off does it need reprogram shootin in the dark need some help please
  4. #24 Re: Car wont start need help erratic rpm
    Check the wiring harness from crank sensor to ICM. Ensure that you reconnected the sensor.
    The TB shouldn't cause a no spark. And if the sensor is hooked up..it shouldn't either.
  5. #25 Re: Car wont start need help erratic rpm
    Out West
    Quote Originally Posted by justin10morrissey View Post
    So good it needed to be posted twice.
    To the OP, Vac leaks?
    Whine with your Cheese?
  6. #26 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    both the icm and cps have 12.3 volts they are getting power its just not getting relayed to eachother possible short? in wire from the cps to the pcm or the pcm itself. or is it possible the car jumped timing??
  7. #27 Re: Car wont start need help erratic rpm
    I went back to reread as I commonly answer too many posts to keep track of everything and found your mention of code P1518. So I looked it up.
    GearChatter.com :: View topic - DTC P1518
    "In some cases the pcm can command the engine off." Hmmmmm Take a look through that as it's the FSM info for the code. Maybe it helps with some fo the testing. I saw something about a shorted wire and thought again about you saying dropped razor and destroyed crank sensor. Maybe there was something else that happened when the sensor was destroyed.
  8. #28 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    possibly ill have to do the steps for the code. also going to recheck the position of the crank shaft sensor its possible that it is not positioned exactly where its supposed to be as a hair off can cause no spark. really need to get this thing going
  9. #29 Re: Car wont start need help erratic rpm
    Nov 2011
    Wolf Point, Montana
    anything guys i just replaced the electronic throttle body
    did you ever consider my solution, couldnt hurt to try looking behind the passenger side headlight and change the Fuel Resistor, this is all part of your fuel system. this solution you will never find in any mechanics manual, but is effective... trust your instincts on this one before you go over budget and the problem turns out to be simple..
  10. #30 Re: Car wont start need help erratic rpm
    Nov 2011
    south carolina
    If you clear the p1518 and then try to start the car, does the p1518 return right away?
  11. #31 Re: Car wont start need help erratic rpm
    SE Level Member justrunningagtp's Avatar
    Nov 2011
    wisconsin dells
    Change the fuel filter. Its cheap and its sounds like what happen to mine..
  12. #32 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    Quote Originally Posted by rocknnachos View Post
    no i can only see it as a history code after i cleared it
  13. #33 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    Quote Originally Posted by Cstealth View Post
    i just dont think thats it im getting fuel im just not getting spark. going to check the postiion of the crank sensor make sure the mounting brackets werent bent
  14. #34 Re: Car wont start need help erratic rpm
    Nov 2011
    south carolina
    So now you're certain there's no spark? Do you have injector pulse?
  15. #35 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    yes i can smell the fuel and see it on the plugs when i hold plug wire up to the coil pack there is no spark nothing at all the icm is good. i swapped it with another 3800 car and it worked fine in the other car. pulled off coil packs to see if by chance all three had gone bad but there still good. im not getting spark
  16. #36 Re: Car wont start need help erratic rpm
    Nov 2011
    Wolf Point, Montana
    [QUOTE=justin10morrissey;691506]yes i can smell the fuel and see it on the plugs when i hold plug wire up to the coil pack there is no spark nothing at all the icm is good. i swapped it with another 3800 car and it worked fine in the other car. pulled off coil packs to see if by chance all three had gone bad but there still good. im not getting spark[/QUoute/] your wasting your time and money, Fuel Resistor, AKA Fuel pump resistor. Common in the grand prix. i gaurantee this will work, Beleive me i already went thru this.. checked the fuel, checked the spark, switched every sensor, even the fuel pump, and nothing till i got alink off this same forum explaining how to change this fuel resistor, real simple procedure, and all my problems wengt away, regretted spending all that money for something so simple...
  17. #37 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    [/QUOTE] your wasting your time and money, Fuel Resistor, AKA Fuel pump resistor. Common in the grand prix. i gaurantee this will work, Beleive me i already went thru this.. checked the fuel, checked the spark, switched every sensor, even the fuel pump, and nothing till i got alink off this same forum explaining how to change this fuel resistor, real simple procedure, and all my problems wengt away, regretted spending all that money for something so simple...[/QUOTE]
    considering this is the only topic you have ever posted about i am somewhat skeptical of your suggestion although i do appreciate you offering a lending hand i do not see how a faulty fuel resistor could cause no spark through the icm to the coil packs. how a faulty fuel resitor could cause an interference between the pcm to the icm. and with a faulty fuel resistor im still getting proper fuel pressure and FUEL. excuse me if i sound rude i just dont appreciate it when people say im wasting my time and how they can gurantee a sure fix especially if theyve never touched my car when it comes to anything there are no guarantees first things first im rechecking my cps then maybe ill get around to checking the horseshoe shaped fuel resistor
  18. #38 Re: Car wont start need help erratic rpm
    Nov 2011
    south carolina
    When the car first acted up, on your way to work, did "reduced power" display on the info center?
    Another thought... c heck the ICM ground. I think it would be at a stud/bolt on the front of the engine, right under the the mount that the ICM is attached to.
  19. #39 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    nothing displayed on the dic the car just kinda surged after pulling away from a stoplight and died it started right back up and basically ran like **** all the way for about a quarter mile and died a couple more times when i was slowly pulling into the lot. i could keep it running if i gave it gas but only above 3k rpms let it sit in the parking space till i got off and would only turn over. got it started with the help of the gas pedal and drove it not even a block till it died for good in the middle of the road and had to push it to a parking space till it got towed. do u have a picture of the ground for the icm its a possibility.
  20. #40 Re: Car wont start need help erratic rpm
    Nov 2011
    Wolf Point, Montana
    considering this is the only topic you have ever posted about i am somewhat skeptical of your suggestion although i do appreciate you offering a lending hand i do not see how a faulty fuel resistor could cause no spark through the icm to the coil packs. how a faulty fuel resitor could cause an interference between the pcm to the icm. and with a faulty fuel resistor im still getting proper fuel pressure and FUEL. excuse me if i sound rude i just dont appreciate it when people say im wasting my time and how they can gurantee a sure fix especially if theyve never touched my car when it comes to anything there are no guarantees first things first im rechecking my cps then maybe ill get around to checking the horseshoe shaped fuel resistor[/QUOTE]
    Well in that case maybe you really shouldnt own a pontiac, a have been reading everysingle post from you to others and still nothing. i have always found something with a man that acnt fix his own cars, let alone have to much pride.. sounds like you have money to burn, hey i guess some people like to learn the hard way, you can thank me when you finally get past all the Bulls**t and realize i was only trying to help... GOODLUCK with your Pontiac, Because i know im going to enjoy mine,..FROM A REAL PONTIAC ENTHUSIAST>>
  1. wont start
    By 65mn in forum General Tech Discussion
    Last Post: 07-20-2011, 04:56 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. erratic idle, stall, one no start... NO CODES!! HELP
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2010, 10:06 AM
  4. Wont Start Please Help
    By Honchop1 in forum General Tech Discussion
    Last Post: 09-11-2010, 08:27 PM
  5. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
