Thread: Car wont start need help erratic rpm
Results 1 to 20 of 41
  1. #1 Car wont start need help erratic rpm
    SE Level Member justin10morrissey's Avatar
    Nov 2011
    Missouri
    hello im new to the forum. i recently bought an 2004 grand prix gt that was supercharged from the factory i am fairly familiar with these motors as ive owned two ssei's before the other day as i was driving the car started to surge dropping from 1500 rpms to 500 then it died. it started back up and barely made it to work. the rpms were very erratic. after work the car would not start it just turned over and over. finally started with the help of keepin it going like it was carbed. couldnt find any unplugged vaccum lines. new 3" downpipe with cat installed bout a month ago it has a slight leak at the front. water pump replaced 3 days ago tensioner pulley is loose and makes a little noise. and a CAI was installed on the car before purchase. any help on this would be very much appreciated i dont want to regret purchasing my first grand prix
  2. #2 Re: Car wont start need help erratic rpm
    clean your throttle body and maf sensor
    does cai by chance have a oiled filter?
    if so that harms maf sensors and can cause issues.
  3. #3 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    its a weapon R intake not sure if its oiled or not but i dont think so
  4. #4 Re: Car wont start need help erratic rpm
    when was your last tune up? check that the wires are not laying on the manifolds too.
    could be a fuel problem as stated earlier.
  5. #5 Re: Car wont start need help erratic rpm
    bg ky
    mine done the same thing i removed the relays and cleaned them and have not had a issue with it any more
  6. #6 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    have only owned the car for 2 months havnt changed plugs just two oil changes and the downpipe and water pump the wires seem fairly new as theyre performance 7mm pulled a plug and saw normal wear no bad signs there. also when trying to start puff of white smoke came out of CAI filter i think it was just a misfire. not quite sure if im getting fuel i can only here it prime to where the fuel filter is but not in the engine bay
  7. #7 Re: Car wont start need help erratic rpm
    Willoughby, Ohio
    sounds like a shotty MAF sensor, i say unplug it and see if it runs better, if so clean or replace it
  8. #8 Re: Car wont start need help erratic rpm
    Coming from the Ei world myself..I can sarcastically say..you made a mistake...lol
    It does sound MAF sensor ish.
  9. #9 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    okay i will give that a try today cleaning the air filter the maf and the throttle body i think what happend was when i blew those coolant elbows maybe the steam from the coolant entered the intake and dirtied up those parts will post results later today
  10. #10 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    ehh i do like the looks of the new grand prix much better than my older bonnies
  11. #11 Re: Car wont start need help erratic rpm
    SE Level Member Hixc's Avatar
    Lawrence MA
    try checking the fuel pressure, It should be in a range of 48-55 psi. any check engine light?
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  12. #12 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    okay cleaning out the throttle body no help. i unplugged the MAF sensor and nothin couldnt even get it started. will be checking fuel pressure tomorrow really need to get this baby back on the road i just bought some new purtty wheels
  13. #13 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    also no check engine lights. im thinkin possibly clogged fuel filter or bad fuel pump
  14. #14 Re: Car wont start need help erratic rpm
    Nov 2011
    Wolf Point, Montana
    I may have the answer to your problem, i had the same problem with my car, and after replacing everything, it was so simple to fix, the problem might be the fuel resistor... the resistor is located in the right-side Qauter panel, right behind the headlight. the resistor looks like a white horseshoe or U-shaped Magnet with a2 wires coming out of itand a connectio at the end. one bolt holds it the the right Qauter panel. this may do the trick and will only cost you around $40 Bucks... Good luck!
  15. #15 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    pulled p1518 code today think thats the direction of the problem
  16. #16 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    p1518 is no link between the electronic throttle control and the pcm
  17. #17 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    anything guys i just replaced the electronic throttle body
  18. #18 Re: Car wont start need help erratic rpm
    Nov 2011
    NY
    Was there an issue over heating engine prior to fixing or replacing pump? Just curious... Crank positioning sensor is sensitive to high heat temps... Not as common a problem but It's something I ran into with my old GP... Just sayin. But others might be able to chime in better on this suggestion? But if it goes, you will see erratic rpm's and even the engine shutting down and not starting cause the computer doesn't know the actual rpms of crank and firing position, etc...
    Hope you find solution!
  19. #19 Re: Car wont start need help erratic rpm
    Nov 2011
    Missouri
    Quote Originally Posted by coolone View Post
    it wasnt really overheating just lost enough coolant to cause steam under the hood but was repaired before it ever overheated
  20. #20 Re: Car wont start need help erratic rpm
    Nov 2011
    Wolf Point, Montana
    Quote Originally Posted by justin10morrissey View Post
    did you ever consider my solution, couldnt hurt to try looking behind the passenger side headlight and change the Fuel Resistor, this is all part of your fuel system. this solution you will never find in any mechanics manual, but is effective... trust your instincts on this one before you go over budget and the problem turns out to be simple..
  1. wont start
    By 65mn in forum General Tech Discussion
    Last Post: 07-20-2011, 04:56 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. erratic idle, stall, one no start... NO CODES!! HELP
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2010, 10:06 AM
  4. Wont Start Please Help
    By Honchop1 in forum General Tech Discussion
    Last Post: 09-11-2010, 08:27 PM
  5. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
