I may have the answer to your problem, i had the same problem with my car, and after replacing everything, it was so simple to fix, the problem might be the fuel resistor... the resistor is located in the right-side Qauter panel, right behind the headlight. the resistor looks like a white horseshoe or U-shaped Magnet with a2 wires coming out of itand a connectio at the end. one bolt holds it the the right Qauter panel. this may do the trick and will only cost you around $40 Bucks... Good luck!
