Thread: Missing help needed
Results 1 to 20 of 27
  1. #1 Re: Missing help needed
    Penn Valley, CA
    Wow...I hope not...I checked out the manual this afternoon and it says they recommend 91 but could run mid grade or regular unleaded rated at 87 but acceleration would be degraded. It does say not to use below 87. Would a compression test on #4 show the chip if its there?
  2. #2 Re: Missing help needed
    Out West
    Quote Originally Posted by ThomasJ2352 View Post
    Running 87 in a 04+ is one of those "no station has 89+ available" kinda things. If it's available to you, run the highest octane possible.
  3. #3 Re: Missing help needed
    Houston
    Yes...cause if the piston chipped, it will most likely damage the valves and they wont seal. You should see a noticeable drop in pressure, if thats the case.
  4. #4 Re: Missing help needed
    Penn Valley, CA
    Ok...just went out to do the compression test on #4...when I tried to remove the plug it was loose Been changing plugs for 40 years and rarely forget to tighten one...cant remember the last time if ever. When I got it out a chunk of the tip was gone as was the center electrode...dropped a replacement plug in and its now back to being the rocket in acceleration but it still idles badly...now I'm getting multiple cylinder misfires...it doesn't feel like its misfiring on acceleration but it sure feels like it at idle.
    Now maybe the clogged CAT? Any way to test it before plunking down $600 for a new one?
    Any more ideas?
    BTW, really appreciate your suggestions.
    Tom
  5. #5 Re: Missing help needed
    Houston
    Did it look like this?
    This was mine...I figured it was a chipped piston, but after a borescope session, piston was fine. You didnt say if the compression was good.
  6. #6 Re: Missing help needed
    Penn Valley, CA
    Your holding my plug! I was so anxious to try it with a new plug I forgot to give the compression a go...in retrospect I need to do that.
    Regarding a CAT...I can only get it from a dealer here in Calif...not allowed to
    buy a used one and auto-parts stores don't carry em for that new of a car.
  1. See if I'm missing anything..........
    By mayoke in forum General Tech Discussion
    Last Post: 08-28-2011, 12:23 PM
  2. ZZP MPS...am I missing something?
    By ls1camino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2011, 09:24 AM
  3. CD player instal, parts needed, advice needed
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 08:53 PM
  4. Am I missing something ?
    By Ladyaz in forum Audio, Security & Visual Electronics
    Last Post: 06-06-2009, 07:14 AM
  5. Do you see anything missing here?
    Last Post: 02-24-2009, 06:26 PM
