Thread: See if I'm missing anything..........
Results 1 to 7 of 7
mayoke See if I'm missing... 08-26-2011, 09:14 AM
mayoke Re: See if I'm missing... 08-28-2011, 09:08 AM
dsmuts Re: See if I'm missing... 08-28-2011, 09:34 AM
mayoke Re: See if I'm missing... 08-28-2011, 10:00 AM
dsmuts Re: See if I'm missing... 08-28-2011, 10:09 AM
txslow6 Re: See if I'm missing... 08-28-2011, 10:38 AM
mayoke Re: See if I'm missing... 08-28-2011, 12:23 PM
  1. #1 See if I'm missing anything..........
    SE Level Member mayoke's Avatar
    Jul 2011
    Norcross, Ga
    I'm mostly quiet and read a lot on here because I don't have any knowledge with S/C engines. To recap, I bought a 2002 GTP with 158k miles on it. Gave it to my mechanic and sank $1300 in getting her running correctly. (Don't worry, I didn't give much for the car.) Now that read through bluegtp91's sticky a bajillion times (Thank you SO much for that), I think I'm ready to move forward.
    The car is a DD and I'm not hard on the car. I never plan on taking it to a strip. I just enjoy annoying the local hondas and F&F crowd. Previous car was a 04 WRX wagon and I know this car is faster than it was. Not from a dig but a roll, it would smash it. The mechanic says the engine is in beautiful condition.
    Ok, I'll get on with it.
    What I'm looking at is moving to a 3.5" or 3.6" pulley. Don't really want the 3.4" as I'm not trying to push anything, I'm just trying to breathe a bit better. (I have a long history of turbo cars.) I'm looking 3.5" pulley, 3" DP, PLOG, and supporting mods for that such as plugs, open cone, t-stat and tune. The tune will be done by my mechanic. He owns a speed shop and tunes regularly.
    I know the headers are cheap and better than the PLOG but I sort of like the stock/sleeper look of the PLOG. If my goal is a slightly quicker DD, does my list look correct? If I've read the sticky correctly, I should be ok but I thought it wouldn't hurt to have some more experienced people look it over compared to my goals. With the list that I'm talking about, how much gain should that be approximately good for? 30-40WHP maybe?
    Thanks for double checking me. I'll take any helpful guidance I can get. here to learn.
    Last edited by mayoke; 08-26-2011 at 09:37 AM. Reason: Forgot to add open cone intake
  2. #2 Re: See if I'm missing anything..........
    Jul 2011
    Norcross, Ga
    I'm guessing this is ok and I got everything right since I haven't been scolded yet.
  3. #3 Re: See if I'm missing anything..........
    I'd get a intake and a set of headers. Then you should be able to run a 3.4 no problem
  4. #4 Re: See if I'm missing anything..........
    Jul 2011
    Norcross, Ga
    Thanks. I was going with the open cone vs. intake since the gains are comparable to slightly better than a CAI and much cheaper. I would PREFER to stick with the PLOG. What are your thoughts on that? If I'm not trying for enormous gains, would the PLOG do what I'm looking for? If I have to go headers, I will but I sort of like the look of the PLOG. (I like the "sleeper" look under the hood.)
    Appreciate your time.
  5. #5 Re: See if I'm missing anything..........
    the headers are probably cheaper than a plog and dp. I meant an open cone intake but i was lazy and just typed intake.
  6. #6 Re: See if I'm missing anything..........
    Texas
    No you're spot on with your list. It will be a nice gain and you should feel a noticeable difference. You could go to a 3.4 with plog, 3"dp, and intake. Add the tune on it and will be a peppy little ride. When you start dropping pulley's you are going to want more. Just fair warning.
    And if you decide to jump over to a turbo kit at some point. The plog can be used and is perfect for a turbo setup.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: See if I'm missing anything..........
    Jul 2011
    Norcross, Ga
    Thanks guys. That's the input I was looking for. Just making sure I had the bases covered. Switching to a turbo later could be......fun.
  1. ZZP MPS...am I missing something?
    By ls1camino in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2011, 09:24 AM
  2. missing
    By bigrig in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2011, 05:03 PM
  3. Seriously missing my HUD
    By itainez in forum General Tech Discussion
    Last Post: 02-21-2010, 05:34 PM
  4. Do you see anything missing here?
    Last Post: 02-24-2009, 06:26 PM
  5. Is something missing?
    By sUpErClEaNbLaCkMaChInE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 07:56 PM
