Thread: Car sounds like crap after LIM Gasket install
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    after installing new lim gaskets my car has this loud noise coming through the throttle body, I thought it was a vacuum leak but i cant find any leaks with carb cleaner and it holds vac pressure just fine. while i was replacing the gaskets i replaced the plugs and wires aswell as made a custom intake and changed the sc coupler. Basically im looking for any ideas im lost. heres a video of what it sounds like. GTP Noise - YouTube
  2. #2 Re: Car sounds like crap after LIM Gasket install
    open cone lets you hear a lot more of the inside of the engine, does the noise let up after the car warms up? if so its normal.
    or put your stock air box back on to make sure.
  3. #3 Re: Car sounds like crap after LIM Gasket install
    Pennsylvania
    No... that is literally the wrong noise. Um. It kind of sounds like a bad coupler?
    Or maybe your intake is vibrating in your fenderwell? It sounds like some hot and steamy metal-on-metal action. Plus a weird whining that sounds sorta like you don't have enough fluid in your power steering reservoir?
  4. #4 Re: Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    Its not throwing any codes btw, i just replaced the coupler and i defiantly doesnt sound like it did with the blown coupler (it sounded like rocks in the sc)
    As for the intake vibrating, it made the same noise with just the stock intake tube on the tb
  5. #5 Re: Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    im gonna let it run for awhile and see what happens
  6. #6 Re: Car sounds like crap after LIM Gasket install
    Sounds like power steering.
  7. #7 Re: Car sounds like crap after LIM Gasket install
    Jersey
    take off the s/c belt and see if it goes away
    16' wrx sti- stock
  8. #8 Re: Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    i used a turkey baster to get some of the ps fluid out and its jet black.
    Should i just get as much as i can out with the baster and dump new fluid in or is there a way to drain it?
  9. #9 Re: Car sounds like crap after LIM Gasket install
    you could take the lines off the rack but that's a lot of work. I'd take as much out of the res as i could and then refill with new.
  10. #10 Re: Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    i noticed it had a whine when you steer and sorta does at idle but thats not the weird noise i was trying to show in the video.
  11. #11 Re: Car sounds like crap after LIM Gasket install
    The whine or the intake noise?
  12. #12 Re: Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    the intake noise is what im trying to figure out, it should be louder because its a short ram intake. it sounds fine at WOT but at idle to like 3grand it sounds like a dying cat
  13. #13 Re: Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    it should sound more like this Grand Prix GTP with cold air intake - YouTube
  14. #14 Re: Car sounds like crap after LIM Gasket install
    Welcome to the world of 3800 intake noise.
  15. #15 Re: Car sounds like crap after LIM Gasket install
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    What the hell? My intake noise sounds nowhere near that lol.
    That sounds so badass though.
    2000 Midnight Blue Grand Prix GTP Coupe
  16. #16 Re: Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    maybe its normal idk? on the downside of things the lim gaskets are leaking again!
  17. #17 Re: Car sounds like crap after LIM Gasket install
    Its in a garage, that amplifies the noise.
    Mine is quite loud as well.
  18. #18 Re: Car sounds like crap after LIM Gasket install
    Nov 2010
    Michigan
    I was talking about the second video he posted.
  19. #19 Re: Car sounds like crap after LIM Gasket install
    Oct 2011
    Illinois
    if your talking about my car, it sounds the same outside.
    I just cant see that as being normal, that intake noise is about 4-5 times louder than the exhaust in person. its to the point it get peoples attention in other cars.
  20. #20 Re: Car sounds like crap after LIM Gasket install
    Put your stock intake on and see if it goes away.
  1. 06 Monsoon sounds like crap
    By Chronosnight in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2010, 04:11 PM
  2. head gasket and lim install and now 2 problems
    By bluedevil3758 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-27-2009, 10:19 PM
  3. Do I need a gasket for a PLOG install?
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2009, 01:11 AM
  4. GM12-AUXV12 sounds like crap
    By Luda in forum Audio, Security & Visual Electronics
    Last Post: 07-15-2009, 02:12 PM
  5. Cai Sounds Like Crap!!!!
    By Gearhed42 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-05-2008, 08:58 AM
