Thread: Cam gear bolt
Results 1 to 5 of 5
  1. #1 Cam gear bolt
    Apr 2011
    sudbury
    Hey guys im ready to take off my cam gear and chain but the bolt on the gear do i turn it clock wise or counterclock wise to llossen it . That bolt is on so tight... And i dont know what way to turn it and cant fit an impact in my car.. How do i do this...
  2. #2 Re: Cam gear bolt
    Omaha, NE
    Your impact probably doesn't have enough torque. Its a bit of a hassle, but if you use a breaker bar, it should be a little easier.
    "Remove the crank bolt using an impact if you have one. If not this is going to be a PITA for you to loosen. Then again the impact may not even take this off. You will need a breaker bar for sure. Have fun breaking it loose. Once it is off we now need that J-tool that will remove the pulley. If you don't have it or can't obtain one here is how you can make one in the next paragraph."
    Eric Buono's Cam Install
  3. #3 Re: Cam gear bolt
    Apr 2011
    sudbury
    Ok i got it losse thanks lol and umm i have a balance shaft question . I have a gtp botto
    End and a gt bottom end and the balance shaft in the gtp bottom end is heavier than the gt balance shaft. Why is that?
  4. #4 Re: Cam gear bolt
    The balance shafts should be identical IIRC
  5. #5 Re: Cam gear bolt
    They are.
    Difference is the GT Cam Gear vs. the GTP one.
  1. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  2. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  3. will this bolt right in?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 08-06-2010, 07:26 PM
  4. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
  5. Bolt Ons?
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-03-2008, 10:06 PM
