Thread: Connecting rod slap or knocking?
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: Connecting rod slap or knocking?
    Apr 2011
    sudbury
    And this is a vid of spark plugs.. Spark plugs normal gtp - YouTube
  2. #22 Re: Connecting rod slap or knocking?
    Apr 2011
    sudbury
    Turns out the cam bearings are shot... Chheck it out : Cam loose gtp - YouTube
  3. #23 Re: Connecting rod slap or knocking?
    Florida
    Oh god...That camshaft is in the wrong place then...
    That sir, is your balance shaft...
    And that does appear to wobble pretty nice...
    Just delete it, and be done with it.
  4. #24 Re: Connecting rod slap or knocking?
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    That sounds like a rocker or a lifter not working. A lifter failing would give that sound I believe.
    Edit - Just saw the above posts on page two.
    You sound the the Russian dude in Russia firing the guns (or at least the commentary sounds like it ) .
    That's a first where I've seen the balance shaft go bad.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  5. #25 Re: Connecting rod slap or knocking?
    did you say look at this nice big cam, and grab the balance'r shaft?
    your cam is under the lifters and has lobes on it and makes the valves move, that shaft you grabbed has none of that.
    i do believe that the front timing cover needs to come of if you want to delete the balance shaft or replace the bearings for it.
  6. #26 Re: Connecting rod slap or knocking?
    Apr 2011
    sudbury
    U can remove the balance shaft? Whats the purpose of it anyways? And anyone know a how to on this
  7. #27 Re: Connecting rod slap or knocking?
    Quote Originally Posted by guimond47 View Post
    Makes the engine smoother...it counter balances the 3800's common rough idle issues...it does nothing but add weight.
  8. #28 Re: Connecting rod slap or knocking?
    Apr 2011
    sudbury
    Soo iwouldnt matter if i just took off the gear and let it sit there? And also read the last thread on this : http://www.grandprixforums.net/camsh...how-54250.html
    Let me know what u think if that will unblance manythings
  9. #29 Re: Connecting rod slap or knocking?
    It won't.
    I don't have one...it just makes the motor rougher at idle.
    Also, quit making a new thread every 5 minutes about the same topic...you can update your old ones.
  1. Connecting rod help...
    By JuggaloDan in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2011, 08:36 AM
  2. Gonna ***** slap you and take your girl
    Last Post: 05-28-2011, 02:13 AM
  3. can you add slap shift?
    By Taz Magister in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2011, 04:16 PM
  4. 3800 s/c knocking noise or piston slap
    By GTPGuRu99 in forum Introductions/Noob Questions
    Last Post: 11-19-2010, 07:03 AM
  5. L67 Connecting Rod Length
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 12:55 PM
