Thread: Running Hot
Results 1 to 20 of 21
  1. #1 Running Hot
    Aug 2011
    Dallas Georgia
    My engine is running hot, flushed radiator, changed tstat, still hot got alittle white smoke out exhaust, oil is fine.What could it be? ? It's an 04 gtp with 100k miles any help will be greatly appreciated. Thanks
  2. #2 Re: Running Hot
    white smoke usually means lim gaskets have gone bye bye's .
    leaking coolant into the cylinders, and then white smoke out the tail pipe.
    hows your coolant level? is it dropping?
  3. #3 Re: Running Hot
    Omaha, NE
    Define "hot"
  4. #4 Re: Running Hot
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    or the head gaskets gone. I'd do a leak down test.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  5. #5 Re: Running Hot
    I'd start by pressure testing the cooling system. If you have an internal leak, it's most likely the LIM's. HG's are uncommon.
  6. #6 Re: Running Hot
    Aug 2011
    Dallas Georgia
    Thanks alot y'all, now how hard are those to change? I can't seem to find a haynes for my gtp any suggestions
  7. #7 Re: Running Hot
    Pretty easy. there are step by step threads here that we can point you to.
  8. #8 Re: Running Hot
    SE Level Member kyrebel's Avatar
    Dec 2010
    Louisville, Kentucky, United States
    lim gasket isn't hard at all first time doing it took me and a buddy about three hours including tear down and assembly but if you can find your leak try using some uv coolant dye thats how i found mine.
  9. #9 Re: Running Hot
    Quote Originally Posted by kyrebel View Post
    Only if it's external, right?
  10. #10 Re: Running Hot
    Aug 2011
    Dallas Georgia
    Lim - lower intake manifold.? I'm not up on the acronyms as far as cars, I'm aircraft mechanic / sheetmetal is my specialty. But I am mechanically inclined, but all this computerized stuff is new to me.
  11. #11 Re: Running Hot
    Quote Originally Posted by NICKS04GTP View Post
    yes lim is lower intake manifold, heres a link to all the common acronyms. it should get you up to speed.
    http://www.grandprixforums.net/common-acronyms-682.html
  12. #12 Re: Running Hot
    Aug 2011
    Dallas Georgia
    Well it looks like I'll be changing a manifold gasket. Do the upper and lower need changing at the same time? If at all possible any links to doing this job would be greatly appreciated! My search buttons are not doing what they should. Now I know to get the metal gasket, I'm going on limited funds so is there any other stuff that's affordable that will need changin? I'm in dallas ga. About 30 minutes from six flags, any help and knowledge would be greatly appreciated! Down to 1 vehicle!!gonna start tomorrow
  13. #13 Re: Running Hot
    Aug 2011
    Dallas Georgia
    After 700 estimate I do believe I'll be changing that lim gasket myself, so any step by step instructions or pictures would be greatly appreciated, I've looked at that video and it should help alot, but any other help or advice will be greatly appreciated!
  14. #14 Re: Running Hot
    I live here. TLSheff's Avatar
    EDIT WHOLE THREAD:
    I remembered where it was hidden
    http://www.grandprixforums.net/video...utes-3112.html
    Video for 2000 GTP (will work for the most part)
    Post# 13 & 16 has parts and how-to info
    If you get stuck just holla
  15. #15 Re: Running Hot
    Aug 2011
    Dallas Georgia
    Thanks I have that video and it should be of great help and so will that link, but one question, I didn't see anything about the super charger? Removal or installation, there was a link in the how to part and didn't say anything about it either, I have a super charger, is there alot of difference with it
  16. #16 Re: Running Hot
    Not really. Whether you remove the SC or the upper intake of an NA motor. It's all a few bolts and a gasket. On the SC, the bolts are torqued to 17ft lbs, on the upper manifold of an NA, they are 89inch lbs.
  17. #17 Re: Running Hot
    Aug 2011
    Dallas Georgia
    Thanks y'all I'll let yitou know how it turns out, hopefully it will be good turn out
  18. #18 Re: Running Hot
    Dec 2010
    man if your were only closer my buddy and i are fixin to start doing the lim gasket for about 300-350. but as a word of advice be ready to purchase new injectors bc if yours are as bad as mine the lower oring retainer will bust into a million pieces!
  19. #19 Re: Running Hot
    you CAN replace those O rings ya know. and you should if your in that deep.
  20. #20 Re: Running Hot
    Dec 2010
    I did replace them but the plastic clip that retains it crumbled orings are only like 6 bucks so that was a no brainer
  1. Car running hot
    By ShinyWhite99GTP in forum General Tech Discussion
    Last Post: 12-26-2010, 10:00 PM
  2. Running no Cat.
    By JoshsGTP in forum General Tech Discussion
    Last Post: 09-17-2010, 04:08 PM
  3. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  4. Trying to get 2.8 running again!
    By 1988 Grand Prix in forum General Tech Discussion
    Last Post: 10-03-2009, 12:35 AM
  5. Got my car running!!!
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 08-02-2009, 01:58 PM
