Thread: Changed heads, burning water
Results 1 to 17 of 17
  1. #1 Changed heads, burning water
    GT Level Member Knightmare's Avatar
    Jul 2011
    Frederica, DE
    Ok, not too long ago we replaced the heads on my 2000 GTP....before we replaced them, it was missing on 3 and 5, after replacing them it was still missing on 3. I was out the other day and was leaving a toll booth, the speed limit was 65, so I got up to 70..not doggin it, just nice normal acceleration, decided I was gonna get up to 80 and set my cruise...once I hit about 75ish..it was kind of like the car choked out..did that a couple of times, then white smoke(steam, whatever) started pouring out of the exhaust...pulled it over, the car shut off and the smoke was under the hood as well. massive blow by..the oil dipstick even gets shot up and smoke/steam funnels around it..what does it sound like to you guys?
  2. #2 re: Changed heads, burning water
    Out West
    Sounds like your tea is ready.
  3. #3 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    oh, btw..it still starts...and the oil is not milky either..lol
  4. #4 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    Quote Originally Posted by Nixon View Post
    I didn't order tea lmao..
  5. #5 re: Changed heads, burning water
    Why did you replace the heads?
    What was the compression like before and after?
    Leakdown test?
  6. #6 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    we replaced the heads because I had a crack on the head at cylinder 3. cylinder 3 was getting no compression before, didn't do one after. I have no idea what a leakdown test is
  7. #7 re: Changed heads, burning water
    SWPA
    You blew a head gasket. You don't have to have water in your oil to be a symptom. Water can go direcly down the exhaust valve if the gasket is blown in the right place.
  8. #8 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    oh..damn damn damn...guess I gotta buy another gasket set then.....doesn't make sense..it's only been a month if that since its been back on the road
  9. #9 re: Changed heads, burning water
    SWPA
    Did you replace the headbolts when you replaced the heads? Did you properly torque the headbolts?
  10. #10 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    yes and yes
  11. #11 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    could it be a problem with the block being warped or cracked? The reason the head was cracked is because it overheated due to a clogged cat while the previous owner had it. I was told there was "no way it could be a problem with the block" by the person who did the head job.
  12. #12 re: Changed heads, burning water
    SWPA
    The block should have still been checked for warpage.
  13. #13 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    well I didn't do that lol..this was my first go 'round with anything like this and I took my stepfather's word....so I take it that it COULD be a possibility then?
  14. #14 re: Changed heads, burning water
    SWPA
    It could be, but all avenues need to be checked to make sure it doesn't happen again. There are times where head gaskets blow for no reason. Saw it happen on a 72 Dart.
  15. #15 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    I will definitely have everything checked out this time..probably even gonna take it elsewhere this time to put it back together lol
  16. #16 re: Changed heads, burning water
    Jul 2011
    Frederica, DE
    thanks
  17. #17 re: Changed heads, burning water
    Have you done any checks?
    Checked the cooolant for exhaust bubbles?
    Checked the pcv? If you blew out the dipstick then you have pressure in the crankcase. A head gasket can let water into the cylinders etc, but that doesn't necessarily put pressure in teh crankcase. A pcv relieves crankcase pressure.
  1. My Car Is Burning Hot Lately
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 07-13-2010, 12:16 PM
  2. Oil Burning
    By 3rdpontiac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2010, 09:23 PM
  3. Burning??
    By gtp99jlp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2010, 02:48 AM
  4. water in heater blower fan or water on passanger floor
    By coolcat2010 in forum How To Write-Ups/Tech Tips
    Last Post: 03-19-2010, 04:20 PM
  5. Thats it, Im burning the ***** down
    By Toofastgs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2008, 08:52 AM
