Thread: Started engine swap!
Results 1 to 12 of 12
  1. #1 Started engine swap!
    Donating Users kyleinkman's Avatar
    May 2011
    canada
    i just thought id share my experience with you guys. Recently as some of you know my Engine in my 03 gtp decided to crawl into a hole and die last friday I orderd a junk yard short block which ill be adding to my mods listas it arrived today lol. I am currently in college for the Motive power technician program so ive decided to document my experience in removing and replacing my engine and I will be sharing that information with you guys. Im hoping it will be helpful to anyone in the future that has to do this. I have been taking pics and vids along the way to help with the visuals. id like to thank everyone aswell on here that has helped me troubleshoot up to this point.
    Im hoping to have my GTP back on the road for friday or monday latest and the Document on the procedure done for wed. any tips and suggestions are welcome along the way
    Thanks Guys
    MODS:
    K&N Intake, Removed mesh air screen, flipped mounts, egr delete, NGK Cooler plugs, NGK wires, 3" pipe, Pacesetter headers, Flowmaster super 44's , 3.4 pulley, 18 inch Fast wheels rims, NanKing ns II tires, Overkill tune, comp cams. junk yard short block
  2. #2 Re: Started engine swap!
    Ummm, lots of beer?
    And ummmm...
    yeah, beer. That's all I got.
  3. #3 Re: Started engine swap!
    Feb 2009
    flintnasty MI
    A cam install video, as well as some "dont do this" type stuff would be nice.
    Commonly I see:
    improper harmonic balancer installs (key missing, jammed into timing gear, etc).
    no cam sensor magnet transfered over.
    not enough RTV on intercooler installs.
    how to replace a motor without a cradle drop (save yourself a $50 alignment, whoo)
  4. #4 Re: Started engine swap!
    May 2011
    canada
    lol Blue if only i could drink in the college..and dark ill do my best to cover those for you
    MODS:
  5. #5 Re: Started engine swap!
    Kyle..try to skip the issues Dark mentioned. Those are the, didn't pay attention type of things.
    Other tips would be to remove the ps pump and ac compressor from the brackets/engine and lay them in the engine bay so you don't have to drain them and reinstall etc. There's room if you keep an eye on them.
    Also..don't need to remove the hood. Just undo the lift support clips and then use a broomstick or something to prop it just slightly higher and you'll never have to fight hood alignment.
    Leave the wiring harness/pcm/batter in the car. They don't need to move. Why do extra work?
  6. #6 Re: Started engine swap!
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    This.
    Also when putting in the new motor and taking it out. Take your jack and stick a small piece of 2x4 on it and jack up differential (passenger side) of the transmission. This will help a lot in getting it out and help more in getting the motor to line up with the with the bell housing of the trans/motor. You will probably need to adjust the jack to keep it level with the sub frame. Just makes life a little easier.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  7. #7 Re: Started engine swap!
    On that jack.. you def need that. The trans on the wussy body cars don't have any support like their huge body brotheren. If you don't help support the diff of the trans, you'll have the trans pulling down and it's not fun. As well as you probably hurt a cv boot in the process.
  8. #8 Re: Started engine swap!
    May 2011
    canada
    cool bill thx for those tips too
    as a progress update: engine will be coming out tomorrow, spent most of today cleaning and doing tests on the new one
    MODS:
  9. #9 Re: Started engine swap!
    May 2011
    canada
    progress update *pulled the engine today! started switching pulleys and such from old to new, (recent 2 month or less replacements such as water pump ect..)
    MODS:
  10. #10 Re: Started engine swap!
    May 2011
    canada
    finally done! had some issues along the way that ill share with you guys just happy to say i got my GTP back! ill be posting the procedure in the next day or so.
    MODS:
  11. #11 Re: Started engine swap!
    Good to hear.
  12. #12 Re: Started engine swap!
    May 2011
    canada
    This is When the Engine came out and one of my buddys from my college making it taste his sweetness haha
    MODS:
  1. engine swap 3800 sc to same but not burned engine
    By roger7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 01:59 PM
  2. engine swap se to gt
    By aperson in forum Engine
    Last Post: 10-22-2010, 06:59 PM
  3. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  4. swap to a non sc engine?
    By projectGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-18-2009, 06:07 PM
  5. Doing an Engine Swap
    By XxJNUGExX in forum Engine
    Last Post: 09-26-2009, 01:29 PM
