Thread: Porting heads. what else while here? want high rpm ability for later...
Results 1 to 1 of 1
  1. #1 Porting heads. what else while here? want high rpm ability for later...
    Florida
    Ok i will be tearing down my l67 heads to begin porting them.... common sense tells me i need to have an old set of valves in there to protect the seats while i port and need to pull the old valve seals to be sure no metal is left after cleaning.
    so far from what i read, the exhaust ports need/ will get the most work. I will gasket match the intake and smooth out the chamber a bit...
    i dont want to waste money of course... but if im this deep i might as well get some stuff done...so what should i do while down this deep?
    so far here i what i know i need:
    -topswap gasket kit
    -set of Viton valve seals
    -will be port matching the LIM and porting blower as well.
    was thinking about SI valves at least for the intake. as i want to be able to rev high.
    also was thinking now would be the time to change the springs since its all apart. i am pretty much decided on a GT2 cam for my own reasons at this time. Since i want higher RPM like around 6500-6700 shift points. should i be looking at 90# or 105's? and then will lifters be a good idea? then again i might be able to wain on the lifters until i do the cam...
  1. pcm interchange ability
    By tedbuido in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2011, 07:31 PM
  2. Porting l26 heads
    By jakewet28 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-25-2011, 07:44 PM
  3. Porting heads
    By monsterjam5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-17-2010, 10:34 PM
  4. Porting Heads. Suggestions Welcome
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 05:56 PM
  5. porting heads
    By blowfishRus6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2009, 08:57 PM
