Thread: Rocker install?
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #1 Re: Rocker install?
    I would also suggest springs. Your car is 10 years old and unknown miles to us. Your springs aren't fresh and may not like the valvetrain being changed up. Keep in mind, you'll be compressing them further.
    Front, I undo the bolts to the coil pack bracket and slide it out toward the battery. Doesn't fully have to come off. Poof done.
    Rear, Rock motor forward. Drain some coolant (in your year) and have a set of coolant elbows on hand. Take the alternator and it's bracket/tensioner and support bracket from rear of motor/sc off. Lift valve cover and you are in. Rear is a little more difficult than the front because the heater hoses are nearby and the EGR bracket also needs to be removed. Overall though, it's a few more steps.
  2. #2 Re: Rocker install?
    Is moving the alt not needed on the 97-98? I didn't even touch the alt when I did mine
  3. #3 Re: Rocker install?
    Nope..the bracket didn't stick over the valve cover in those years.
  4. #4 Re: Rocker install?
    GTP Level Member biggt's Avatar
    Jul 2010
    Montreal
    Souds pretty easy, how many bolts are holdding the rocker? 1?
    02 SilverMist GT L67 SWAPPED
    Quote Originally Posted by RedDawnGXP View Post
    Yeah plus he has a lot of weight reduction with the clear corner lights.
  5. #5 Re: Rocker install?
    Battery removal is also unnecessary.
  6. #6 Re: Rocker install?
    Dat's why I sez'd it.
  7. #7 Re: Rocker install?
    May 2008
    Winnipeg, MB
    was not necessary for me to remove the coil pack for the front valve cover, just the fuel rails, and dog bone brackets
    I did have to take off the alternator, serpentine belt, coolant bottle, engine brackets for the rear valve cover
    2007 Pontiac Grand Prix
  1. ARP lube for rocker install. What for?
    By Rust in forum General Tech Discussion
    Last Post: 12-18-2011, 10:04 AM
  2. 1.9 Modified Rocker Install
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-10-2011, 06:59 PM
  3. any Tech Tip for rocker install?
    By Mitchstrp in forum General Tech Discussion
    Last Post: 01-04-2011, 09:56 PM
  4. Rocker install
    By mikesarebetter in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-10-2010, 06:07 PM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
