So I have a 2004 GP GTP with 52k miles. I have recently noticed the car doing something very strange and I can't find any similar problems online. When I put the car in drive and start going the car starts moving and then suddenly stops accelerating. The RPM's start dropping (900-400) and the car seems like it is going to die. The further I push on the gas the worse it sounds. Then while I am still pushing on the gas it finally catches up and the car suddenly accelerates (usually squealing the tires). The car also did it today while in reverse. It is a very intermittent problem and usually occurs when the car is warmed up but it seems to be getting worse. This only seems to happen just after shifting the car into gear. It has never happened after I have been driving for a while.
Car is stock except for a 180* T-Stat and Spectre air intake. I also already cleaned the throttle body. The transmission shifts smooth and there is no slippage. Has anyone ever heard of this problem or have any suggestion to what it might be? The next thing I am going to do is change the fuel filter and plugs but I seriously doubt they have anything to do with it. Any advice would be much appreciated.
