Thanks for all the help guys. she lives again!
Got the engine in and it started right up and idles smooth.
Now I need to fix the tail pipe at the "Y" because that is broke and then off to get emmisions tested. Once that is complete I can get the plates.
I got all the gaskets changed and replaced the lower motor mount and vacuum lines. Cleaned the throttle body, replaced the SC oil, changed the plugs and wires and filters. I also got all the old dexcool out and took the radiator to a shop to be flushed so I could put some regular "any color" coolant in. I replaced the radiator hoses, cap and thermostat.
Hope it was all worth ot and it stays running good for a while.Thanks again for all the suggestions and helps along the way. This has been a great site.
