Thread: rod knock or something else?
Results 1 to 20 of 32
  1. #1 rod knock or something else?
    Donating Users
    Aug 2011
    Lowell, IN
    Hello. It's my first post. It's not that I have been avoiding you guys it's just that I never had a Pontiac Grand Prix before. But now I need your expertise.
    I bought a car for my daughter. I knew that it had some engine problems but I liked the car so I bought it. It's a 1999 Pontiac Grand Prix GTP. The guy said that it had a rod knock. So I went and looked at it. When I started it at first there was no rod knock and then after a minute it started. It does increase as you give it gas.
    I drove the car home and it drove well but would knock pretty load when taking off from a light. Then when it would shift at about 35 the knock would pretty much go away. it may have been there faintly but I couldn't really hear it. Then we I got closer to the house I got on it a bit more. No huge knocking or anything and the car accelerated well and ran good. Then as I got close to home the car really was not running real well and seemed like it wanted to quit.
    I have no warning lights and my code scanner shows no DTC, temp is good. I out up some vidoes to see what your opinions are.
    The car was maintained well and I have all the records. The car has 101,000 miles and the oil was changed regularly. The guy said it was his sons car who now works in D.C. and so the car has been sitting in the dads driveway for over a year. However, the dad would take it for a drive about once a month to keep everything going. He took it out one day and then he heard the sound. before that it ran great and they were going to drive it out to D.C. until this happened. I am ready to throw a new engine in it but first I want to get some other opinions.
    It doesn't just knock but it makes quite a bit of noise. Sounds like metal or like a bearing on a pulley. Also I found a vacuum ose disconnected because the connector and rotted and split. I did put that back on but after that the cars seems to want to surge when it is ideling. It's also kind of hard to keep it running now when you pull it into the garage or out.
    Trans fluid is full and looks good. Oil looks clean and was actually a nit over full. I drained some out.
    So take a look at the videos and tell me what you think. If I have not put you to sleep yet
    2011-08-27_13-41-06_330.3gp - YouTube
    2011-08-27_13-41-59_623.3gp - YouTube
    2011-08-27_14-27-25_218.3gp - YouTube
    2011-08-27_14-27-58_825.3gp - YouTube
  2. #2 Re: rod knock or something else?
    HUDSON
    Fubar flexplate.
  3. #3 Re: rod knock or something else?
    Jun 2011
    Detroit, MI
    LOL in the videos it doesn't even sound like the engine is running, but it doesn't quite sound like rod knock.
    I had rod knock and here is a video of it: 1998 Grand Prix GT :: 013.mp4 video by joebom123 - Photobucket
    Probably flex plate or something. Clean it up too!
    Oh and mine was very slow and stalled when putting it in reverse, and chugged at slow speeds with rod knock, $1200 later, its fixed...
    iLoveSpade
  4. #4 Re: rod knock or something else?
    Donating Users
    Aug 2011
    Lowell, IN
    Thanks for the replies guys. Hippo Machine - Honestly I think that my third video sounded just like yours. I have that same squeeky/chipping should along with the knock. Also, after I got it home it started running like it was going to quit. It would run real slow and the oil light would flicker real lightly here and there.
    When you put it in gear and let off the brake it wanted to quit so you had to two foot it just to back up and go forward a little bit.
    I know that to even fix the flex plate I have to pull the engine. Is there anything else that you guys would suggest checking before I pull it?
  5. #5 Re: rod knock or something else?
    Jun 2011
    Detroit, MI
    Do you see any coolant leaking anywhere or the LIM gasket material melting around the edges of the LIM? Cuz thats what killed mine, otherwise, I have no idea.
    iLoveSpade
  6. #6 Re: rod knock or something else?
    Donating Users
    Aug 2011
    Lowell, IN
    On the back side of the engine I see a lot of oil. I can smell the oil burning also. I also smell coolant a little when the car is running.
    Coming home there was no smoke or steam out the tail pipe even when getting on it a little bit.
  7. #7 Re: rod knock or something else?
    Jun 2011
    Detroit, MI
    Is there enough oil in it?!?!?!?!
    *Goes to check oil for first time*
    iLoveSpade
  8. #8 Re: rod knock or something else?
    Donating Users
    Aug 2011
    Lowell, IN
    Yes LOL. second to the last line of my OP. I checked it and it's clean. it was a little bit overful so I drained some out. Now it's right on the button.
  9. #9 Re: rod knock or something else?
    Jun 2011
    Detroit, MI
    What did you record the video with? Cuz it doesn't even sound like the engine is running lol, it sounds funny.
    iLoveSpade
  10. #10 Re: rod knock or something else?
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    It's a rod. Time for a short block.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  11. #11 Re: rod knock or something else?
    Donating Users
    Aug 2011
    Lowell, IN
    I visually inspected the flexplate the best I could from under the car. However, in my mind I would not see a crack that runs around the bolts holding the flex plate. So do you think that it would be a good idea to take the bolts off from the torque converter to the flex plate then see if I can get movement in the flexplate?
    I know that in the end it will probably be a rod and I can deal with that. The thing that is bothering me is this -
    1. The car was very well maintained and I have all the records of regular oil changes and maintenance. why would the rod go at 100,000? Could happen but seems unlikely.
    2. The noise seems like it is coming from the area of the flexplate/transmission. At one point I thought -is it the trans?
    And lastly, this has nothing to do with this problem but when I picked up the car it was almost out of gas so stopped and put regular octane gas in the car. I noticed in the manual it says to use premium. Do you guys use premium in these cars or what?
  12. #12 Re: rod knock or something else?
    Maintenence meaning the Lower Intake Manifold gaskets? If they were never replaced with the metal replacements...and still used the factory ones and the dexcool was never totally flushed out of the system...then that's the issue.
    Dexcool is a killer on plastic stuff.
  13. #13 Re: rod knock or something else?
    Donating Users kyle91's Avatar
    Jun 2011
    Michigan
    Most of us do unless we tune it for other gas. I run 93 all the time and will never put in 92 or 91.
    current mods: DIY FWI, res & u-bend delete, SD headers mated with custom 3in downpipe, 2.5in catback with turbomax muffler, autolite 104s, 180 t-stat, poly mounts, can tune, 3.4 mps
    soon to be mods: NIC cam, possibly dna springs
  14. #14 Re: rod knock or something else?
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    You could use Regular, but it honestly won't run as good as with Premium.
  15. #15 Re: rod knock or something else?
    Donating Users
    Aug 2011
    Lowell, IN
    At 96,000 the following work was performed:
    Supercharger gasket
    plenum gasket
    lower intake gasket
    heater bypass tubes
    antifreeze
    What do you mean "then that's the issue"? I don't quite understand what your saying.
  16. #16 Re: rod knock or something else?
    I was saying if those gaskets hadn't been serviced...or if there was previous damage done by not replacing them sooner...what happens is the dexcool eats away at the factory plastic gaskets over time...and leaks down into the rotating assembly...even if the car was properly maintained...I've seen some lock up due to failing LIM gaskets (if they weren't replaced with metal ones vs. plastic ones that is)...that's what I was trying to get at...
  17. #17 Re: rod knock or something else?
    Donating Users
    Aug 2011
    Lowell, IN
    I understand now. I appreciate the wisdom.
    So far I have found most of the little rubber vacuum connectors to be dryrotted ad cracked. I am going to replace those so that the vacuum is tight everywhere. Then I am going to remove the belts so taht I have no accessories running and see if I hear any change.
    If the above does not produce results then I will take the bolst out out the torque converter to flexplate and see if I can figure out if anything is wrong with the flex plate.
    If again I get no results then I will pull that motor out and put in another one.
  18. #18 Re: rod knock or something else?
    Well...in order to swap the flexplate either the transmission has to be dropped out...or the motor has to come out the top...so if your replacing the flexplate...you might as well swap the bottom end...and get headers...and cam it...and put a supercharger on it LOL
  19. #19 Re: rod knock or something else?
    Feb 2009
    flintnasty MI
    Flexplate replacements can be done in car by just pushing the motor and trans apart.
  20. #20 Re: rod knock or something else?
    Working harder, not smarter...sure.
  1. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  2. 00 GT rod knock
    By Sameyeam in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-11-2010, 05:57 PM
  3. help with the knock please
    By BankRupt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2010, 02:29 PM
  4. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  5. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
