hey, would anyone be able to explain what a whipple kit is, and what are some of the benefits of using that to replace the old supercharger? I'm looking into different areas to mod a gtp,and i have a question about this one. thanks guys.
Michael
Michael
How about we start with you need insane cooling mods that cost more than the car is worth.
And the fact that a whipple is also worth more than the car is.
Might as well go turbo or pick a new platform.
Matt, you forgot to mention how hard it is to find a whipple these days...
i know about the cooling and all the supporting mods. I'm thinking about picking up a 6 speed GTO, or a GTP. The thing is, the GTO is around 18k, then plus mods on top of that. But you can pick up a GTP for pretty cheap and then put not close to that in mods and still achieve some good times. You see?
I know a guy that's running 11s for $2k in a GTP. No whipple.
still modded gtp < gto anyday
so 2k for a tranny, plus 3k in mods and yay 350whp in a gtp, or having a manual and v8 in a gto?
yeah.
GTP can do fast for cheap.
But it isn't fun.
Nor can they turn well.
Two grand into turning and you're still better off with a different platform.
**** the goat, get a C5.
Who needs to turn when you're drag racing?
I'd rather stick with a platform that not everybody else and their moms have, and mod something else to be faster.
So you'd rather spend money to hit 12's instead of start there?
If you shop smart... LS1 powered F bodies can be had for the cost of a decent W body and enough mods to run 12's.
Note I'm not saying bottom barrel cars here... We all know you CAN get that mystical $500 W body that just needs a starter or a battery.
the GTO would have an sts rearmount turbo kit on it (supporting mods and all the stuff too). and i just recently thought of the whipple kit. I was thinking3.0 maybe lower for the GTP with supporting mods. and one of the main reasons i want the GTO is for stick.
rear mount turbo's aren't a good idea.
Turbo systems use the thermal energy of the exhaust to generate power so by giving it more time to cool down, thats lost power.
LS2, H/C/I/Spray, some tires and some seat time...10's.
Unless you just prefer the GTP, there really is no point in going with one.
why would you say the turbo isn't so good? i've heard otherwise from a few people. and by the way, i love the sound of turbo. (i'm just trying to get different views)
more tubing under the car, turbos more exposed to road hazards speed bumps etc. less psi then normal system
Turbo good.
Rear mount turbo bad.
Got it? Good.
