Thread: Questions about a Whipple Kit
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
  1. #41 Re: Questions about a Whipple Kit
    Dec 2010
    illinois
    not where i'm from then. there are so many g8s, only two gtos.
  2. #42 Re: Questions about a Whipple Kit
    Waukesha, WI
    theres alot of gtos in the scrapyard by me,
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #43 Re: Questions about a Whipple Kit
    Feb 2009
    flintnasty MI
    If you want to do a whipple... just remember this is not a kit for it out there and you are going to be doing a ton of fab work ( which means you need to know excatly what the hell you are doing).
    There are a few adapter plates for whipples floating around, but they will not do you any good due to the fact you still need to craft a billion more parts that are far more complicated... and typcially the crap adapter plate just gets in the way more than it helps.
  4. #44 Re: Questions about a Whipple Kit
    Troy OH
    mmmmmmm whipple... i wish. whipple chargers are generally considered "better" because they compress the air inside the blower housing, leading to (correct me if i'm wrong) denser charge and lower outlet temps. there used to be a kit for the 3800's, but it's been long since discontinued. they're extremely hard to find as well. there was one member on this forum that had a whipple setup, but i haven't seen him around for a year or so. basically, they're really expensive and way overkill. it would be pretty cool though
  5. #45 Re: Questions about a Whipple Kit
    What is with this "hard to find" stuff?
    All you need is a TB adapter plate and a custom intercooler. WHICH...IIRC...Paul at PRJ or Tom Wright down in Whicita, Kansas (Guy who ran AnimuL Performance back in the day) still have those parts or templates.
    As for the blower...
    It is just a Whipple W140AX.
    You can buy just the blower and make your kit. Probably run about 3K, ish.
  6. #46 Re: Questions about a Whipple Kit
    Sounds like cam versus intercooler...
    Cam is great if you can get it in there for 700. Better value than intercooler at 1200-1500.
    However paying someone for a cam install brings you right back into intercooler range. (PRJ charges 500 as per his site)
  7. #47 Re: Questions about a Whipple Kit
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Why is it that people suggest turbo's over CSC? Is it because a turbo kits are more accessible and your on your own for a CSC?
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  8. #48 Re: Questions about a Whipple Kit
    SWPA
    Because turbos have more potential.
  9. #49 Re: Questions about a Whipple Kit
    Newnan, GA
    Is that because the belts on the CSC limit how much boost can be made, whereas a turbo the limit is exhaust velocity/pressure?
  10. #50 Re: Questions about a Whipple Kit
    Feb 2009
    flintnasty MI
    no CSC's can be nasty....
    They are sorta a ***** to setup, and sorta crap on small displacement motors
  11. #51 Re: Questions about a Whipple Kit
    Waukesha, WI
    the hey thats differant factor is hard to beat though
    RayRay
    92 Turbo miata
    02 lexus is300
  12. #52 Re: Questions about a Whipple Kit
    Vancouver, WA
    Apparently I need to move by you guys because all I ever see are civics
    Slowest 'Cooled Gen V ever
  13. #53 Re: Questions about a Whipple Kit
    Waukesha, WI
    midwest ftw lol
    RayRay
    92 Turbo miata
    02 lexus is300
  1. Any experence with whipple supercharger?
    By kirkkarem1212 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2011, 09:21 AM
  2. some whipple cobra slaying
    By darkhorizon in forum Track Sessions and Kills
    Last Post: 08-09-2011, 02:20 PM
  3. 1999 GTP with Whipple W140AX - 537 WHP
    By IN2DeeP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2009, 06:52 PM
  4. Animul whipple charger
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2008, 09:28 PM
  5. How Much Do Whipple Superchargers Add
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-22-2008, 10:38 PM
