Thread: coolant elbow broken inside engine
Results 1 to 20 of 28
  1. #1 coolant elbow broken inside engine
    Aug 2011
    cecil, pa
    Hi! I'm new to this forum, so I was wondering if anyone could help me. I have a 2002 GTP and thought the water pump was leaking, but after I took off the belt tensioner, I found out that the front L shaped elbow on the tensioner was broken off inside the intake manifold. This is where the coolant is leaking from. I wondered if anyone knows how the coolant flows inside the engine or specifically inside the intake manifold? I can't reach the piece that broke off, if I take off the water pump will I be able to reach it? I can barely feel it with my finger. I really don't want to take apart the manifold to reach a small piece of plastic.
  2. #2 Re: coolant elbow broken inside engine
    Omaha, NE
    Have you tried using a screwdriver at an angle to pry it out?
  3. #3 Re: coolant elbow broken inside engine
    Aug 2011
    cecil, pa
    Yes, it moved down and to the left, and I can't get anything inside the hole to get it out. I can barely feel the piece with my finger and there is not enough room to get a tool inside there to remove it. I wonder if I could push it down more and took off the water pump if I would be able to see it?
  4. #4 Re: coolant elbow broken inside engine
    Texas
    Just pull the lower intake manifold that's gonna be your best bet. I typically use a pic type tool that has a L on the end of it. Never has an issue doing it that way. Good luck.
    85 Corvette
    01 TA
    03 Z06
  5. #5 Re: coolant elbow broken inside engine
    dig that sucker out. get a pick tool or very small screw driver and crack it and pull it out.
  6. #6 Re: coolant elbow broken inside engine
    Florida
    I just did my elbows last week and same thing happened. I just used all 5 fingers, a few tools, and curse words and bam i got the lil piece out after 25min.
  7. #7 Re: coolant elbow broken inside engine
    Aug 2011
    cecil, pa
    I wondered if the water pump that sits just below this hole immediately leads to the lower intake manifold? If I remove the water pump will I be able to access the piece of plastic?
  8. #8 Re: coolant elbow broken inside engine
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    It goes out of the Lower intake manifold and goes from the coolant elbow into the tensioner. Behind the tensioner there's a larger plastic elbow that it goes to and into the water pump. I'd just take the other 3 bolts off the tensioner and replace that as you might as well replace both coolant elbows. Both elbows are around $5 at the parts store under the "Help" section.
  9. #9 Re: coolant elbow broken inside engine
    I've always been able to dig them out. It's one of the most common things we all get to do.
    Pulling the wp won't help. the timing cover is the backside to the water pump and that would be in your way.
    FWIW I use a blind pilot bearing tool to pull the pieces. Can't use it on the LIm while it's on the motor, but otherwise, it's the quickest easiest way to getting the whole piece out in record time.
  10. #10 Re: coolant elbow broken inside engine
    Aug 2011
    cecil, pa
    Thanks!!!
    Followed advice and found elbows at NAPA and AutoZone. $3.95 for both in a package. I couldn't reach the broken piece, it broke just after the o-ring seal and the ring size piece kept moving further into the manifold. So.... I got out my shop vac and sucked the hole out until the piece was where I could reach it and pull it out.
    Thanks for all your advice!!!
  11. #11 Re: coolant elbow broken inside engine
    Oct 2012
    Roseville MI
    need help on step by step replacing this part please if anyone could. the elbow just blew apart today while driving and drained all the coolant. i had the same part replaced about 3 months ago. i had no choice to drive the car home about a mile and was running almost to the red on the temp gauge, and is now making some slight knocks and ticks when i cooled it down and then ran it again for 30 seconds or so.. did i do major damage or is this normal?
  12. #12 Re: coolant elbow broken inside engine
    a 3 second search shows this jem.......http://www.grandprixforums.net/how-c...ows-49779.html
  13. #13 Re: coolant elbow broken inside engine
    Oct 2012
    Roseville MI
    thanks. its similar but i have a GP and the elbow is directly into the block and seems to be a different than the one hes doing.
  14. #14 Re: coolant elbow broken inside engine
    what engine? is it a 97 or 98?
  15. #15 Re: coolant elbow broken inside engine
    Oct 2012
    Roseville MI
    nope, 2002 GP GT, bone stock. the same piece had cracked before and was leaking but i had it replaced and was working fine for a few months with no leaks. then today it literally blew up and shot coolant everywhere while i was driving. im not sure why this happened and im hoping it didnt cause major damage
  16. #16 Re: coolant elbow broken inside engine
    if its a 3800 engine, follow that link, they are all the same. except for the 97 and 98, they have a cast elbow for a lower elbow.
  17. #17 Re: coolant elbow broken inside engine
    Oct 2012
    Roseville MI
    thanks man ill give it a shot.
  18. #18 Re: coolant elbow broken inside engine
    St. Louis
    Quote Originally Posted by 0 lbs boost View Post
    Well, was it making this noise before you blew the elbow? These motors can take some overheating but anything is possible. Best bet would be to replace the elbows, clean the belt and ALL the pullies off so no coolant is left on them and fire it up after refilling w/ coolant and see what it sounds like. Worst case take a vid of it and post it here and we can try and help.
  19. #19 Re: coolant elbow broken inside engine
    Apr 2011
    Elk Rapids, Michigan
    When you get the new elbows, get the aluminum ones from Dorman. I got mine at OReilly's for about $12. They're much better than the plastic ones.
  20. #20 Re: coolant elbow broken inside engine
    GT Level Member 88formula's Avatar
    Oct 2012
    West Branch, MI
    Has anyone used the Aluminum elbows from ZZP? seems like these would be much less prone to breakings, so they would be a great investment assuming they work good. Anybody have any input?
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  3. coolant elbow leak again
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2011, 10:33 PM
  4. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
