Thread: coolant elbow broken inside engine
Results 1 to 20 of 28
  1. #1 Re: coolant elbow broken inside engine
    Texas
    Just pull the lower intake manifold that's gonna be your best bet. I typically use a pic type tool that has a L on the end of it. Never has an issue doing it that way. Good luck.
    85 Corvette
    01 TA
    03 Z06
  2. #2 Re: coolant elbow broken inside engine
    dig that sucker out. get a pick tool or very small screw driver and crack it and pull it out.
  3. #3 Re: coolant elbow broken inside engine
    Florida
    I just did my elbows last week and same thing happened. I just used all 5 fingers, a few tools, and curse words and bam i got the lil piece out after 25min.
  4. #4 Re: coolant elbow broken inside engine
    Aug 2011
    cecil, pa
    I wondered if the water pump that sits just below this hole immediately leads to the lower intake manifold? If I remove the water pump will I be able to access the piece of plastic?
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  3. coolant elbow leak again
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2011, 10:33 PM
  4. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
