Thread: coolant elbow broken inside engine
Results 1 to 20 of 28
  1. #1 Re: coolant elbow broken inside engine
    Omaha, NE
    Have you tried using a screwdriver at an angle to pry it out?
  2. #2 Re: coolant elbow broken inside engine
    Aug 2011
    cecil, pa
    Yes, it moved down and to the left, and I can't get anything inside the hole to get it out. I can barely feel the piece with my finger and there is not enough room to get a tool inside there to remove it. I wonder if I could push it down more and took off the water pump if I would be able to see it?
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  3. coolant elbow leak again
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-06-2011, 10:33 PM
  4. coolant elbow broken, will not come out.
    By kingfish in forum General Tech Discussion
    Last Post: 02-26-2010, 08:17 PM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
