Thread: cooling system questions
Results 1 to 7 of 7
  1. #1 Re: cooling system questions
    Quote Originally Posted by ibhuff View Post
    im pretty sure i bled the system thoroughly, should water seep from the bleed screw? cuz i filled the radiator to the top with the bleed screw open, water did not seep from it but the rad was full and i filled it with the bleed screw open. i will see if i cant get more air out of the system in the morning. thank you
    are you bleeding the engine while its running? it should be a steady stream of coolant jetting out of the bleeder screw.
    i like to idle the car with the rad cap off, till the fans come on, that way you know the t-stat is open, top off rad, open the bleed screw, bleed, tighten the screw, top off rad if needed, and cap it.
  2. #2 Re: cooling system questions
    PA
    Agree with the masses that you did not bleed all the air out completely.
    2001 GSE
  1. Cooling System
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:44 PM
  2. Help understanding the Cooling System.
    By genesis in forum General Tech Discussion
    Last Post: 12-29-2010, 12:47 PM
  3. cooling system question
    By iluvbst in forum General Tech Discussion
    Last Post: 12-05-2010, 10:07 AM
  4. Cooling system flush
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2010, 12:16 PM
  5. Cooling System Issues
    By CSteen85 in forum General Tech Discussion
    Last Post: 07-28-2010, 06:47 AM
