Thread: cooling system question
Results 1 to 10 of 10
iluvbst cooling system question 12-03-2010, 08:00 PM
kfish Re: cooling system question 12-03-2010, 08:00 PM
matt5112 Re: cooling system question 12-03-2010, 08:01 PM
TheOtherNick Re: cooling system question 12-03-2010, 08:39 PM
iluvbst Re: cooling system question 12-03-2010, 08:55 PM
TheOtherNick Re: cooling system question 12-03-2010, 08:58 PM
iluvbst Re: cooling system question 12-03-2010, 09:08 PM
iluvbst Re: cooling system question 12-04-2010, 08:46 PM
QUICKSILVER462 Re: cooling system question 12-05-2010, 10:00 AM
trickytransam Re: cooling system question 12-05-2010, 10:07 AM
  1. #1 cooling system question
    SE Level Member iluvbst's Avatar
    kissimmee,fl
    Ok looking at my coolant hoses today while the car was running, and when I give the car throttle both coolant hoses suck in. Now everything that has to do with cooling is brand new or fairly new.do I just need to put coils in the hoses? Probly going to do that anyways. just wanted to know if there could be any other causes...
  2. #2 Re: cooling system question
    Donating Users kfish's Avatar
    Ohio
    if your sucking the hoses shut, you need to bleed the system.
  3. #3 Re: cooling system question
    feel the hoses. if they're rock hard or way too soft then they need to be replaced.
  4. #4 Re: cooling system question
    Charles City, IA
    Your hoses probably need replaced and you need to bleed the system.
    SMGPFC Two Nipple General
  5. #5 Re: cooling system question
    kissimmee,fl
    Ok, thanks for the fast replies..what's the proper way to bleed the system on this car?
  6. #6 Re: cooling system question
    Charles City, IA
    Get it up to operating temp, turn the heat on high, let the car run and open the bleeder on top of the thermostat untill only coolant comes out, A no spill funnel on the rad helps keep the coolant higher than the engine while you do this helping get air out. You will have to do this a few times to get the air out.
  7. #7 Re: cooling system question
    kissimmee,fl
    Ok thanks..going to try it as we speak.
  8. #8 Re: cooling system question
    kissimmee,fl
    Ok replaced bottom hose (kinda soft) and bled until straight coolant was coming
    Out the bleeder top hose stopped for the most partan but the bottom hose is still sucking in. Not as bad if course cause of the new hose..but still lost
  9. #9 Re: cooling system question
    HUDSON
    Not trying to sound redundant, but do you have a thermastat installed, if so, is it insalled correctly? Is is possible it is stuck wide open? Also, is your rasdiator cap in good condition? If the system is not holding pressure like it should, it could be the cause of your hoses sucking in.
  10. #10 Re: cooling system question
    SE Level Member trickytransam's Avatar
    Michigan
    Drill a hole in the thermostat T plate to help it self bleed. Tiny, like 1mm or less.
  1. Help understanding the Cooling System.
    By genesis in forum General Tech Discussion
    Last Post: 12-29-2010, 12:47 PM
  2. Cooling system flush
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2010, 12:16 PM
  3. Cooling System Issues
    By CSteen85 in forum General Tech Discussion
    Last Post: 07-28-2010, 06:47 AM
  4. Cooling system bleeders
    By JenHello in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-21-2009, 09:52 AM
  5. Cooling system question
    By BDEGhost in forum General Tech Discussion
    Last Post: 11-13-2009, 08:24 PM
