Thread: Cooling system flush
Results 1 to 2 of 2
  1. #1 Cooling system flush
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    I am in the middle of doing a cooling system flush and each time I remove the bottom radiator hose to drain it off, I get about a gallon of coolant/water out. Since the system holds just over 12 quarts, that's about 1/3 of the whole system coolant. What is the capacity of the overflow bottle? I want a 50/50 mix when I refill and just topping off with pure anti-freeze won't get me that if I'm only draining off a gallon at a time.
    If I drain the radiator and start the car, the t-stat is still closed, so I doubt it will refill with what is left in the block. Is there a drain plug on the block that is easily accessible or is there a better way to do this?
  2. #2 Re: Cooling system flush
    Charles City, IA
    Pull the front knock sensor out of the block. It is kinda under the exhaust manifold.
    SMGPFC Two Nipple General
  1. Cooling System Issues
    By CSteen85 in forum General Tech Discussion
    Last Post: 07-28-2010, 06:47 AM
  2. flush your clogged cooling system on your 3800!
    By Spazztic2003 in forum How To Write-Ups/Tech Tips
    Last Post: 07-02-2010, 12:21 AM
  3. Cooling system bleeders
    By JenHello in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-21-2009, 09:52 AM
  4. Cooling system question
    By BDEGhost in forum General Tech Discussion
    Last Post: 11-13-2009, 08:24 PM
  5. Coolant System Flush
    By zofsharick@gmail.com in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2009, 08:59 PM
