Easy way to rule out a FP or not...if it ONLY does it at IDLE...flexplate noise goes away once there is load on the motor. I can't see the video since I'm at work...but if that isn't the case...I'd be looking into the bottom end.
not 100% of the time... A cracked one will wobble and whatnot under load.
