Thread: Engine knocking/odd sound
Results 1 to 9 of 9
  1. #1 Engine knocking/odd sound
    GT Level Member backinblackgtp's Avatar
    Nov 2009
    centereach, NY
    i was driving my car home from work the other day, casually, i stop at a red light roll down my window and when im at the light i lowered my music because i heard a noise... best way/ best video i can find already uploaded that matched the sound almost identically is this....
    ‪2000 GTP Knocking Noise..flexplate?‬‏ - YouTube
    ... i just dont know if its a rod, flex plate, bearing... or what. i dont understand how this can possibly happen with 105k miles, i change the oil ever 3k-4k miles.
  2. #2 re: Engine knocking/odd sound
    Windsor (ON) Canada
    There is a flexplate video that came up after I watched yours, similar sound.
    Just a guess though.
  3. #3 re: Engine knocking/odd sound
    GT Level Member Wrongwayislost77's Avatar
    Arvada, Colorado
    Sounds like a flexplate for sure. Mine just came loose, it didn't crack. The jackwagon that assembled my drivetrain at the factory didn't put any blue loc-tite on the crank bolts and a couple were backing out, and 5 were hand tight! Flexplate is an easy fix, and a cheap one, but it's labor intense pulling the motor. Might as well throw in some goodies while you're there though.
    Sig2
    30%, 5000k's, GMPP/Addco Sways, BMR Braces/Arms, FE3 Struts, WBS Springs, 12" w/ SS Lines & F-Bodies. Wiz, HVTB, HV3, CPlog, Shift Kit, ZZP 1.0, Alt/Volt Boost, Etc.
  4. #4 re: Engine knocking/odd sound
    Easy way to rule out a FP or not...if it ONLY does it at IDLE...flexplate noise goes away once there is load on the motor. I can't see the video since I'm at work...but if that isn't the case...I'd be looking into the bottom end.
  5. #5 re: Engine knocking/odd sound
    Feb 2009
    flintnasty MI
    not 100% of the time... A cracked one will wobble and whatnot under load.
  6. #6 re: Engine knocking/odd sound
    Nov 2009
    centereach, NY
    i would say it does it when i accelerate too, but it seems like if im doing 40 or more, i cant hear it, i mean my cars kind of loud, but still i think i would be able to hear that.
    would a mechanic be able to snake a camera in to check?
  7. #7 re: Engine knocking/odd sound
    St. Louis
    Possible, but you may be able to tell if something is wrong by taking the inspection cover off the bottom and having a look. That's about the only place I would think you could even begin to look around for issues. Of course if it's a bolt loose or a crack around the center area, then you may be stuck.
  8. #8 re: Engine knocking/odd sound
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    You can see quite a bit of the flex plate from underneath the car (just the one side), if you get someone to turn the motor over by hand while you have a look.
  9. #9 re: Engine knocking/odd sound
    Charles City, IA
    Drain the oil and see if its silver.
    SMGPFC Two Nipple General
  1. knocking sound
    By casperyaj in forum General Tech Discussion
    Last Post: 03-27-2011, 08:43 PM
  2. knocking sound
    By scott1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2011, 08:46 AM
  3. knocking sound from engine
    By BSP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 09:03 AM
  4. knocking sound
    By kenneth74gt in forum General Tech Discussion
    Last Post: 08-24-2010, 04:13 AM
  5. Ticking/knocking sound in engine compartment
    By 200GpGt in forum General Tech Discussion
    Last Post: 04-17-2010, 03:54 PM
