Thread: 3.5" Pulley/ Exhaust
Results 1 to 20 of 40
  1. #1 3.5" Pulley/ Exhaust
    Aug 2011
    oshawa
    Hello fellow Prix owners, you guys rock. A month back i bought a used 1999 Grand Prix GTP Supercharged. It has about 175,000 clicks on er, and is bone stock. I've been impressed so far with how fast it can go, except i want it to go faster. Today i installed a K & N Cool Air Intake Filter, haven't quite noticed much of a difference but i guess i'll take the manufacture's word for it and assume i'm getting more power. I've read that a new pulley for the supercharger is a good bang for your buck HP booster. Would i be able too install the 3.5" pulley as is or are there any other mech component's i should consider upgrading to help the car deal with this extra HP. Also I'm not a fan of exhaust system, or atleast the exhaust tips, can i install new tips myself? and which exhaust tips/ upgrades are best for the GTP? Thanks guys, these forums are legit.
  2. #2 Re: 3.5" Pulley/ Exhaust
    Grand Island, Nebraska
    Well you should have just made your own intake, and I wouldnt believe the manufacturers claims. You can find a cheap set of headers off ebay for $200 and they will replace the restrictive front manifold and infamous u-bend. exhaust tips are only for looks, and yes you can install them yourself. the clamps may be really rusted on there though. get whatever tips you like, dual/duals are very popular. you may be able to get away with a 3.5 on your basically stock engine, but you would absoultely need a scan/in car/dyno tune with it.
  3. #3 Re: 3.5" Pulley/ Exhaust
    Delaware, OH
    Read this and treat it as your W-body Bible.
    http://www.grandprixforums.net/safel...car-17482.html
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  4. #4 Re: 3.5" Pulley/ Exhaust
    Out West
    Upgrades or bust.
    On stock guts/intake, exhaust flow. You will be pushing about 10% more air through the car. You will see more boost with a 3.5 pulley, but buddy, boost aint what you want. 3.5 pulley on stock drivetrain = boost stacking.
  5. #5 Re: 3.5" Pulley/ Exhaust
    Aug 2011
    oshawa
    Awesome link, thanks. What do you mean by Boost Stacking? As read in the bible, looks as though i'll be buying new spark plugs/wires next.
  6. #6 Re: 3.5" Pulley/ Exhaust
    you dont need colder plugs yet really.
    boost is a measure of restriction. for example, my car sees 5 lbs of boost, 6 max (rarely). a stock GTP sees what, 10? all my flow mods increase flow which means less restriction and less boost, yet more power.
  7. #7 Re: 3.5" Pulley/ Exhaust
    Out West
    Quote Originally Posted by JoRoW99 View Post
    Depending on air density and temperature, A stock GTP or other L67 powered car will see 4-11psi on a stock pulley (YES, i've personally seen it vary by that much.)
    Colder plugs on stock pulley....I'd go 605's, if you go 3.5 pulley, go 104's
  8. #8 Re: 3.5" Pulley/ Exhaust
    Aug 2011
    oshawa
    Thanks. So for example i aspire to go with the 3.5" pulley, if i were to put that in tomorrow, how would my car respond?
  9. #9 Re: 3.5" Pulley/ Exhaust
    Probably not that badly. BUT I would rather be safe than sorry and get a tune at the same time.
  10. #10 Re: 3.5" Pulley/ Exhaust
    Out West
    With no other mods?
    If your car wasn't knocking before (doubtful) -- It will after you slap a 3.5 on it.
    You might feel a seat of pants difference of ~10hp, maybe 20lb-ft tq to the crank. Hardly enough to be measurable. -- This is because your car will be pulling timing.
  11. #11 Re: 3.5" Pulley/ Exhaust
    Aug 2011
    oshawa
    KK. I read in another thread that you risk blowing your motor with that kind of power, what would balance the pulley out to avoid any potential drawbacks?
  12. #12 Re: 3.5" Pulley/ Exhaust
    Its not the power that would blow the motor, its the knock. And headers would balance it out, or at least a 3" downpipe. I really wouldnt run any more boost without scanning for knock.
  13. #13 Re: 3.5" Pulley/ Exhaust
    St. Louis
    Headers, highflow cat and a Aeroforce scangauge and tuning software would be a good start. Then maybe some diff. plugs. Just read through the link posted on safely modding the 3800. Could you run the 3.5" w/ no flow mods? Sure. But how long, probably not very. Then you will learn the hard way as you chip pistons and are finding a new longblock.
  14. #14 Re: 3.5" Pulley/ Exhaust
    Antioch, IL
    headers, tune, 180tstat
    2009 Challenger SRT8
    Expert at being gay.
  15. #15 Re: 3.5" Pulley/ Exhaust
    IMO I wouldnt run a colder t-stat. I know that most people on here will disagree but i dont see the point. heat=power.
  16. #16 Re: 3.5" Pulley/ Exhaust
    Out West
    Quote Originally Posted by FordMan77 View Post
    I'm sure you could run a 3.5 forever with NO flowmods. As long as you didn't punch it too often.
    The point is, pulley and no flow mods = negligible gains, and decreased reliability.
  17. #17 Re: 3.5" Pulley/ Exhaust
    Aug 2011
    oshawa
    Ok, so from what I've read in the bible, it's either you upgrade the downpipe and front manifold or you purchase headers. Which option is better?
  18. #18 Re: 3.5" Pulley/ Exhaust
    Out West
    Headers.
  19. #19 Re: 3.5" Pulley/ Exhaust
    swift current,sask.
    Headers by far are the best option, then with a decent tune you could be looking at a 3.4" setup
  20. #20 Re: 3.5" Pulley/ Exhaust
    As far as I'm concerned, PLOG and DP are obsolete.
  1. Any 2.25" in by 3" out by 5" long exhaust tips out there?
    By Xanthous in forum Visual/Body Modifications
    Last Post: 06-05-2011, 09:09 PM
