Thread: Thermostat & Radiator Questions
Results 1 to 20 of 33
  1. #1 Re: Thermostat & Radiator Questions
    GT Level Member UCF04GPGTPCompG's Avatar
    Nov 2009
    Clermont, Florida, USA
    Ran well today, stayed just under the middle point of the temp gauge. I decided to buy a 195*F thermostat cause as some of you said, along with the guy at the shop, unless I have a scanner to change the settings of the engine/fans and such, a 180*F won't help me much/if any. I figured even if the Thermostat is working fine, I can replace it now that I'm over 100K and it will be good for well over another 100K and I won't have to worry about it at all. Plus who knows how dirty it is with the old radiator fluid and all, so I may as well take it apart to clean around there anyways, and replace the thermostat while doing that.
    I bought the RTV sealant since i guess I'm supposed to use that to seal around the bolts and such. It says it's 24hr. cure time, so I guess I'll do this and have to now drive the car for a day. Should i use the RTV sealant just around the two bolt holes? or should i make a bead all the way around the housing as well to create a full seal?
    2004 Pontiac Grand Prix GTP Competition Group (250K)
    Engine Mods: K&N Air Intake, ZZP 3'' Downpipe w/MagnaFlow Cat
  2. #2 Re: Thermostat & Radiator Questions
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    I didn't use any on mine and it's fine.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. Best thermostat
    By ATLgrandprix78 in forum Introductions/Noob Questions
    Last Post: 08-12-2010, 08:55 AM
  2. Thermostat Questions
    By mycutlassblue in forum General Tech Discussion
    Last Post: 02-15-2010, 10:43 PM
  3. Thermostat!????
    By fratzke7 in forum General Tech Discussion
    Last Post: 03-16-2009, 11:35 AM
  4. Thermostat Questions
    By redrunner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 07:40 PM
  5. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
