Thread: Sudden Engine Knock
Results 1 to 13 of 13
  1. #1 Sudden Engine Knock
    Jul 2011
    Iowa
    I have a 2000 Grand Prix gtp with 160,000 miles. This past weekend I suddenly noticed pretty loud engine knock. To me in sound like a lifter knock but I am not certain. I know the Dex-Coolant can eat away the gaskets and I needed an oil change anyway so I changed the oil thinking I would be able to tell if there was coolant in the oil. Long story short I couldn't tell but the coolant level is not noticaably dropping. With the new oil the knock got drastically quieter, after a few loud ones and, I presume thats because the oil haden't reached where ever the knock is. Anybody got any ideas on what can cause a valve knock to suppenly appear. Its barely audible under 1500 RPMs and really loud above 3000. No noticable power lost but It not like im going to push it with the engine knocking like that. I used the old screw driver method to see If I could hear where it was coming from with no luck.
  2. #2 Re: Sudden Engine Knock
    Very tough to say. how about getting us a vid so we can verify if it's valve etc to help you out.
  3. #3 Re: Sudden Engine Knock
    I live here. TLSheff's Avatar
    Compare to videos on page one of this current thread. If it sounds like this, read on... if not a video of what your is doing would help greatly.
    http://www.grandprixforums.net/engine-knock-49093.html
    PS ^^^ Is NOT lifter noise, so hopefully yours isn't like this one
  4. #4 Re: Sudden Engine Knock
    Jul 2011
    Iowa
    I went to to auto parts store and one said it was a rod knock and one said it was a lifter knock but niether was sure. Im leaning toward the rod knock but really, really dont want it to be that. I dont really knowhow to upload videos so I just linked on to on youtube. Thanks for your help.
    ‪engine knock‬‏ - YouTube
  5. #5 Re: Sudden Engine Knock
    rod knock.
    does the oil have sparkles in it???
  6. #6 Re: Sudden Engine Knock
    Jun 2011
    Detroit, MI
    Quote Originally Posted by fivefingerdeathpunch View Post
    rod knock.
    Does the oil have sparkles in it???
    ooohhh pretty sparkles
    iLoveSpade
  7. #7 Re: Sudden Engine Knock
  8. #8 Re: Sudden Engine Knock
    Jul 2011
    Iowa
    Damn, well i thought it was a rod knock but I was praying it was not because that and my motorcycle are my only mode of transport. I didn't see any shavings in the oil. I believe the oil plug even has a magnet that didnt have any shavings in it. But who knows. Anybody got a LS37 engine fore sale or ideas on Engine swaps. Will a more powerful engine even fit in this car?
  9. #9 Re: Sudden Engine Knock
    find another L67 and just swap them.
  10. #10 Re: Sudden Engine Knock
    Sep 2013
    bearing flakes are not normally magnetic.
  11. #11 Re: Sudden Engine Knock
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Could be main bearing knock too. Happened to me before with a l67.... You won't always see metal in the oil because the drain hole is higher than the bottom of the oil pan. Main or rod knock doesn't matter the lower end is toast. I bought a junk yard motor for $750 with 110k and swapped the motor myself. If you can't do the wrenching a good shop can for around a grand.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  12. #12 Re: Sudden Engine Knock
    Its from 2011.... Why?
    ... W H Y ? ? ?
  13. #13 Re: Sudden Engine Knock
    Washington Michigan
    ... W H Y ? ? ?
    LMAO!!! I didn't even notice that!!!! Doh!!! I just saw the recent activity and responded lol
  1. Engine Knock
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:49 PM
  2. Engine Ping/knock help!!!
    By Qbarclay in forum Engine
    Last Post: 05-16-2011, 11:16 AM
  3. Engine knock???
    By MagnoliaMak in forum General Tech Discussion
    Last Post: 03-15-2011, 07:52 PM
  4. Need help, Engine Knock
    By valleyd01 in forum General Tech Discussion
    Last Post: 10-02-2009, 06:28 PM
  5. Do I have Engine knock?
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-02-2008, 07:59 AM
