Could be main bearing knock too. Happened to me before with a l67.... You won't always see metal in the oil because the drain hole is higher than the bottom of the oil pan. Main or rod knock doesn't matter the lower end is toast. I bought a junk yard motor for $750 with 110k and swapped the motor myself. If you can't do the wrenching a good shop can for around a grand.
