I assume you use the swagelok fittings to connect from the metal fuel lines? Is there anywhere else to get the same thing? I still cant figure out what fittings to use to connect to the stock fuel rail. If i could find that out I think i could figure out the fittings for the rail connector to the hose and then from the hose to the metal line connector.
