Thread: SS fuel Lines
Results 1 to 7 of 7
  1. #1 SS fuel Lines
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Has anyone here run Stainless steel fuel tubing from the engine bay to the actual tank? I don't want to use anymore than like 2 ft of SS flex fuel line as I personally don't trust it over a solid line (my friends SS brake lines ruptured after 6 months). I'm planning at running solid lines from the tank all the way into the engine bay by the master cylinder. Then running a 2ft SS flex line from solid line to the stock fuel line and use A.N. fitting at both junctions.
    Is the fuel line supply 3/8 while the fuel return 5/16?
    3/8 line I'm looking at
    eBay Motors: 3/8" 304 Stainless Steel Brake Fuel Line Tube Tubing 8' (item 310044802238 end time May-25-08 09:06:39 PDT)
    5/16 line I'm looking at
    eBay Motors: 5/16" Stainless Steel Brake & Fuel Line Tube Tubing 1' (item 310044688203 end time May-24-08 20:48:47 PDT)
    Any one know what the rear brake tubing line size is? I might replace those as well.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  2. #2 Re: SS fuel Lines
    Moore, Oklahoma
    Those are the stock sizes, why you replacing all the hardline? If I were you, i'd just cut off the stock plate line and run your SS line there. It would be a lot easier...
    Shawn W. Larsen
  3. #3 Re: SS fuel Lines
    Oklahoma
    That is an interesting idea. However, I dont think 8' would be enough. Id think you would need more than that to make it one solid, continuous run. A polished or at least a bright stainless steel line would sure look better than the OEM lines.
  4. #4 Re: SS fuel Lines
    Schaumburg, IL
    My stock lines look pretty rusted, and I figured since I have no classes this summer (college) this would be the perfect time to replace them so I don't have one that rusts through and would cost me a fortune if I was away from home and didn't have tools with me.
    I believe the ebay auction person is able to get me coiled SS 304 tubing, which I would purchase like 12 ft or so of both sizes.
    I dont trust SS flex line, that's why I want to limit the SS flex and use SS tube as much as possible. Did I mention the stainless steel tubing would be Alcohol friendly as well.
  5. #5 Re: SS fuel Lines
    Oklahoma
    I for one would appreciate any write up and pictures and stuff like that you could do if you proceed with this cause I would like to do this myself and them being alcohol friendly adds a certain zing to it for those wanting to run an E85 setup.
    Anyway, if you have the time and means, document it as fully and completely as you can as I think this would be a how to that would come in handy in the community.
  6. #6 Re: SS fuel Lines
    Schaumburg, IL
    I just dropped my cradle for the first time since I'm going to rebuild my transmission this week. That thing took me 6 hrs to get it out. There was quite a bit parts to move more than I though would be necessary. I have two extra bolts I didn't label, so I need to find out where I removed them from.
    While I'm waiting for the rest of my trans parts to come in, I'm going to hopefully start buying the Parts I need to get this fuel line setup working.
    I'm documenting my cradle removal as well as anything else I do. So if I have time to get the SS fuel lines installed, I'll definitely have it documented.
  7. #7 Re: SS fuel Lines
    Oklahoma
    That is great. I cant wait to see it all.
  1. Custom AN Fuel Line setup for PRJ Fuel Rails... [*]
    By Iron Indian in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2009, 07:53 PM
  2. Transmission lines to radiator
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2008, 10:45 PM
