one more to add i changed my supercharger oil and now im getting full boost so one issue down one more to go!
sweet man.. did that stuff stink?
haha
Yea it was pretty nasty stuff! But it helped a lot. Do you have any idea why I am still having the crank pressure? Even after changing the pcv? No codes and I just leave my dip stick out ( to relieve the pressure) and it drives fine but I really want to fix the issue
lets try to narrow this down a bit.
the pcv system has 2 parts.
1) suck out crank case gases etc (input to Pcv valve)
2) allow fresh air into crank case to replace sucked out air
if number 2 is not working, you will be creating vacuum in the crank case and air will be flowing INTO the oil dipstick hole to replenish
I suspect that might be the case...
otherwise you could have larger issues if you have pressure in the crank case.. could be caused by poorly sealing piston rings (blow-by)
try and cover the dipstick hole with your finger while in park and figure out if its blowing or sucking.
Pressure usually means the pcv isn't functioning. Aka it's blocked, the SC gasket wasn't cut for the pcv, an intercooler is blocking it etc.
the dipstick is definitely sucking air in. so what could be my issue where would i start ive replaced the pcv and o-rings im not sure what to do next i havent had my SC off and i am stock other than my few mods listed. is there a way to track down which part of my pcv system is having the issue?
