Thread: Half Boost PCV issue?? please help
Results 1 to 12 of 12
  1. #1 Re: Half Boost PCV issue?? please help
    utah
    Quote Originally Posted by tylerbinski View Post
    sweet man.. did that stuff stink?
    haha
    Yea it was pretty nasty stuff! But it helped a lot. Do you have any idea why I am still having the crank pressure? Even after changing the pcv? No codes and I just leave my dip stick out ( to relieve the pressure) and it drives fine but I really want to fix the issue
  2. #2 Re: Half Boost PCV issue?? please help
    GT Level Member tylerbinski's Avatar
    Canada
    lets try to narrow this down a bit.
    the pcv system has 2 parts.
    1) suck out crank case gases etc (input to Pcv valve)
    2) allow fresh air into crank case to replace sucked out air
    if number 2 is not working, you will be creating vacuum in the crank case and air will be flowing INTO the oil dipstick hole to replenish
    I suspect that might be the case...
    otherwise you could have larger issues if you have pressure in the crank case.. could be caused by poorly sealing piston rings (blow-by)
    try and cover the dipstick hole with your finger while in park and figure out if its blowing or sucking.
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  3. #3 Re: Half Boost PCV issue?? please help
    Pressure usually means the pcv isn't functioning. Aka it's blocked, the SC gasket wasn't cut for the pcv, an intercooler is blocking it etc.
  4. #4 Re: Half Boost PCV issue?? please help
    utah
    the dipstick is definitely sucking air in. so what could be my issue where would i start ive replaced the pcv and o-rings im not sure what to do next i havent had my SC off and i am stock other than my few mods listed. is there a way to track down which part of my pcv system is having the issue?
  1. Getting half boost at the gauge.
    By falcz420 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 02:56 PM
  2. DIC boost guage half filled WOT
    By Perry125 in forum General Tech Discussion
    Last Post: 11-02-2012, 11:28 PM
  3. half boost and bogging
    By undecided in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2011, 10:50 AM
  4. only have half boost
    By gtp225 in forum Introductions/Noob Questions
    Last Post: 09-25-2010, 01:32 PM
  5. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
