Ive done extensive searches trying to diagnose this problem and almost thought I had it taken care of.
Heres the story.
Bought an 01 GTP a couple months ago. Started driving it daily about a month ago. When I bought the car the guy said it had a stalling problem but he thought they fixed it with a new fuel filter. Obviously thats not the case.
My girlfriends father is the service manager at a GM dealer. He brought it into the shop and said it was the mass airflow sensor. So we replaced it.
After that it still had been stalling rarely but starting right back up. Every few days or so. Also I noticed off the line at WOT it pings something mean around 3500-4000 rpms. So I avoid making it do that at all costs.
Then it started to stall everyday and lit up the SES. Then a few times a day and not starting again for ~5 minutes. Checked it with a basic scan tool and got a 0420 low efficiency bank 1. Then even cold it wouldnt start unless you cleared the code. Now it seems that the 0420 code is a problem many people spend lots of money trying to fix. A lot of the answers i found said clogged cat or bad rear O2. Girlfriends father seems to think that bad rear O2 wouldnt cause it to stall and not start. Im also unsure if a clogged cat would make it stall randomly and sometimes not start again.
Like how could it be not so clogged it can run most of the time but clog up to a point where it chokes it out other times?
SO he thought it was the front O2. He brought home that super GM scan tech 2 or something tool home and we replace the front O2. After that everything seemed golden. He checked everything with the tool and it seemed fine. And for 2 days after the change it only stalled once and started back up. Yesterday it stalled in traffic and wouldnt start again for about 5 minutes. Then this morning same thing and this time SES light back on. I dont currently have the scan tool but when i do ill pull the code. Its probably 0420 again. And it still pings.
I use premium fuel only from places like mobil or shell. No ****ty cheapo places.
This car has no mods other than my stereo setup. It had a K&N filter but he said that might have been what killed the MAF but IDK so theres a paper one there now. I checked all the vac lines and some are cracked a little but I taped the **** out of them until i get new ones.
I have this heavy feeling that the pinging is directly related to this stalling issue. Or its been running wrong for a long time and the cat is getting more and more clogged. I also thought maybe bad cam position sensor setting the timing off but there hasnt been any codes for that.
Any help would be great. If anyone needs more info I can give it other than the current code. The scan tool may be back tonight if its in the truck but if not ill have it monday night.
