Thread: kr opinion aussie l67
Results 1 to 10 of 10
  1. #1 kr opinion aussie l67
    Jun 2011
    Whyalla, South Australia
    Hi people. Im getting some knock when off boost also when coming of the gas. Getting some when upshifting at wot also. Theres no kr at wot throttle just randomly as described.Just after some more opinions. Im thinking it maybe false knock.
    2000 model 145000 klm 180-183 comp on all cylinders.
    Composite stealth cooler
    Isx2 cam 105 springs manley retainers double roller vitons
    Ported blower outlet
    Cold plugs
    Ported lim inlet
    Resonator delete
    Custom base tune
    running 13psi/79mm pulley seeing 10 psi max on gauge.
    Im suspecting false knock as the tune is very conservative max timing at wot is 10d and my w/b shows 10.9-11.0 af at wot. Also running 98 octane with octane boost added.
    aussie spec stock exhaust is twin system twin cats/mufflers so flows ok
    Other info maf reading is10500 wot. Coolant temps around 85c . I have a log file but its tuner pro if any1 is keen for a look. Thanks guys.
    ken
  2. #2 Re: kr opinion aussie l67
    11 is damned rich.
    try 11.2.
    11.5 or so if you're intercooled.
    How are the plugs burning?
    Nice and browned?
    Whats the AFR shoot to when you let off the gas?
    Can you not upload the log to scandepot?
  3. #3 Re: kr opinion aussie l67
    Jun 2011
    Hey mate ive never heard of scandepot lol. If you can read tunerpro files from there ill post the log right now. Do you need the definition file also?
    Cheers mate. When the missus gets back from shopz ill post a pic of plugs.
  4. #4 Re: kr opinion aussie l67
    It seems scan depot is down at the moment so thats not an option.
    Are you able to export the file in an excel spreadsheet?
    If so, that'd work just swell.
  5. #5 Re: kr opinion aussie l67
    Jun 2011
    Ill have a crack at exporting it cheers mate.
  6. #6 Re: kr opinion aussie l67
    you could not try any harder at being stereotypically aussie....
  7. #7 Re: kr opinion aussie l67
    i like the way Austrians talk, sounds cool, better than a us southern accent, at least i can understand them,(Austrians) i got the New York thing going for me, but if you could toss a few shrimp on the barbie ill be right down lol
  8. #8 Re: kr opinion aussie l67
    Jan 1970
    Maquoketa, Iowa
    Do you play with Decel settings?
    Only thoughts are that it runs pretty rich and after playing with that a lot, the decel tables may need some tweaking.
    Also sounds like a little false KR coming from the trans.
  9. #9 Re: kr opinion aussie l67
    Jun 2011
    Hey there. Ive not touched any tune adjustments the base was made up for me to build on hence the low advance and rich a/f. Im still at the logging and researching stage. I wanna have a good understanding of tuning before i jump in. Anyway, whilst out cruising last night @30mph steady throttle like 3-5% running of boost in vac i look down to see kr build to 8d then slowly trail off. It surely cant be real. So i look i my log nothing strange all normal.
    on another note it appears im maxing out my maf tables @ 245 gs @5000rpm after this gs is flat at 245 and it leans slightly even with a stock exhaust.. Considerind the cam makes more power after 6k im gonna have to go mafless or adjust tables so this tune is irrelevant really.
  10. #10 Re: kr opinion aussie l67
    Feb 2009
    flintnasty MI
    Try decreasing the PE enable point. In american PCM's the table is called "PE TPS% enable". Set it so that you get more PE at lower TPS%.. stock in american cars is like 43%, most set it to 28-32%.
  1. Rim Opinion
    By abuckley1290 in forum Tires & Wheels
    Last Post: 01-22-2010, 09:17 AM
  2. HUD opinion
    By racecardude310 in forum Off Topic Discussion
    Last Post: 01-12-2010, 09:25 PM
  3. Rim opinion
    By Infinity9999 in forum Tires & Wheels
    Last Post: 11-20-2009, 01:18 PM
  4. Aussie says Hello
    By OZ38 in forum Introductions/Noob Questions
    Last Post: 09-17-2009, 11:42 PM
  5. cam opinion
    By uNda6gT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-22-2009, 08:23 AM
