Thread: My thoughts on E85 GTP's
Page 4 of 4 FirstFirst ... 234
Results 61 to 73 of 73
  1. #61 Re: My thoughts on E85 GTP's
    Brownsburg
    I feel blessed, not only is there an e85 station a block from work but there installing another one across the street AND they just added one at the closest station to my house...barely a mile away.
    For the "I'm scared of losing lubrication" crowd get on bitog and look up tcw3. Been using it for about 10k on 93 and w the e85. Seems to work well, no residue on the plugs thats for sure. There's a 50 page thread with a couple years of documented use. At $12 a gallon and taking about 3oz per average fillup it lasts a long, long time.
    I never told PRJ it was in the tank when he tuned and asked him if anything was out of the ordinary and he, nor his wideband could tell so its not going to affect your tune as long as you keep the correct ratio going.
  2. #62 Re: My thoughts on E85 GTP's
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    The info in here is great i decided im going corn fed in 2 weeks, i just gotta wait on injectors that im gunna buy with my next check. i've had no luck in finding any used 65#ers so whats the cheapest place to pick em up.
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  3. #63 Re: My thoughts on E85 GTP's
    Nov 2008
    Waterloo, Iowa
    ZZP sells em for $300 as does wbodystore.
  4. #64 Re: My thoughts on E85 GTP's
    Minnesota
    Quote Originally Posted by shawnschuldt View Post
    Siemens 60 LB Injectors - Over The Top Performance
  5. #65 Re: My thoughts on E85 GTP's
    Jul 2011
    B-Town, PA
    do want.
  6. #66 Re: My thoughts on E85 GTP's
    Jun 2010
    Beloit, WI
    anyone else heard of this place? is it legit? id be more than happy to save some money by getting them here
    --00 Red GTP--
    13.07@108mph
  7. #67 Re: My thoughts on E85 GTP's
    Nov 2008
    Waterloo, Iowa
    Will those work? It says Cobalt on the page...
  8. #68 Re: My thoughts on E85 GTP's
    Minnesota
    They will work. They are the same thing and even let you choose between EV1 and EV6. I have heard that they have great customer service and the injectors are flowmatched.
    You could even do these for less than what ZZP charges:
    http://www.ottperformance.com/store/...s-258p1153.htm
    There is shipping though so you have to add that in.
  9. #69 Re: My thoughts on E85 GTP's
    Jun 2010
    Beloit, WI
    wouldn't 80# be way overkill?
    --00 Red GTP--
    13.07@108mph
  10. #70 Re: My thoughts on E85 GTP's
    Topeka, KS
    That OTTT Performance used to be a vendor on here. You just gotta put 6 injectors on the page when you order vs 4.
  11. #71 Re: My thoughts on E85 GTP's
    Jan 1970
    Maquoketa, Iowa
    Ev6 is 04+
    Ev1 is 97-03
    80# are like 550whp plus on E85 range...
  12. #72 Re: My thoughts on E85 GTP's
    GTP Level Member AjL227's Avatar
    IL
    I went with 80#/hr, because I have access to E85 and I know this car will be turbocharged in the future.
    Unless, you know you will desire a turbocharged setup with E85 fueling, 80#/hr are overkill.
    Another reason I went with 80#/hr injectors is because of the returnless style fuel system on my car. There are no racetronix fuel pumps available for my generation. Say the fuel pressure drops significantly during a high engine load condition, every little bit more my injectors can compensate gives me more headroom from detonation.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  13. #73 Re: My thoughts on E85 GTP's
    Jun 2010
    Beloit, WI
    makes sense, im just getting the 60's because im not really planning on throwing a turbo in anytime soon
    Edit:just bought them from ottp for 266.82 shipped
    --00 Red GTP--
    13.07@108mph
  1. your thoughts
    By Glider Girl in forum Off Topic Discussion
    Last Post: 04-10-2011, 01:36 PM
  2. I Want your thoughts.
    By shawngtp in forum Tires & Wheels
    Last Post: 11-08-2010, 09:29 AM
  3. Thoughts on 12's
    By grannyprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2010, 02:43 PM
  4. Thoughts on 911.....
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 09-21-2010, 07:03 PM
  5. Well I Need Some Thoughts...
    By SlickGTP in forum Off Topic Discussion
    Last Post: 01-14-2008, 01:28 AM
