Thread: O2 sensor replacement gone wrong
Results 1 to 5 of 5
  1. #1 O2 sensor replacement gone wrong
    GTX Level Member Juanmiguel's Avatar
    Mexico
    So I've been getting O2 DTCs for the past few days, I delete them and they come back, so I decided to replace it with a Duralast sensor earlier today, but when we turned it back on the car would run like crap so we put back the old sensor and to our surprise, it still ran like crap.
    The O2 sensor wires were extended a few months back to fit the headers so we proceeded to check the wires. After removing the tape we found no problems with the wires, so we taped them back together and connected the old O2 sensor back, but this time I disconnected the PCM fuse a few minutes, now it's running normally.
    Did I miss something here? I'm not really sure what to do next, I was thinking on testing the signal on with the scanner to see if I'm getting the right voltage.
  2. #2 Re: O2 sensor replacement gone wrong
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    How did you construct your o2 sensor extension?
    For all your 3800 needs:
  3. #3 Re: O2 sensor replacement gone wrong
    If your extension isnt' soldered, automatically solder it. Heat shrink and solder are you best friends when working on stuff exposed to the elements. Another possibility is if the O2 wiring touches the plug wires, it'll cause quite a stir.
  4. #4 Re: O2 sensor replacement gone wrong
    Mexico
    The harness extension is actually soldered, I didn't do it btw, it was the mechanic who did it, but I guess he got it right. I may try to keep it away from the plug wires.
  5. #5 Re: O2 sensor replacement gone wrong
    I like to run it behind (over and behind) the heater core hoses to keep it off the wires.
  1. Low Oil Level Light Still Comes On After Low Oil Level Sensor Replacement
    By LoveMyGPGT in forum General Tech Discussion
    Last Post: 04-23-2017, 09:20 AM
  2. Crankshaft Position Sensor Replacement [*]
    By SyntheticShield in forum How To Write-Ups/Tech Tips
    Last Post: 11-23-2014, 12:54 AM
  3. Fuel Sensor Replacement ?
    By jstanfield103 in forum General Tech Discussion
    Last Post: 01-05-2011, 05:38 PM
  4. Left rear speed sensor replacement
    By steverichmond in forum General Tech Discussion
    Last Post: 10-25-2010, 04:46 PM
  5. downstream oxygen sensor replacement help!
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2010, 08:41 PM
