Thread: Need help w O2 sensor fail
Results 1 to 13 of 13
  1. #1 Re: Need help w O2 sensor fail
    I'm sorry, it looks like I failed and put way too much oil in on the last oil change :/ Oil level is where it should be now & low oil light is off. Id still like to know why the light was on. The low oil light dosent come on for low tranny fluid does it? Just curious.
    no low fluid light for the trans, you need to check it after its warm, as the level of fluid drops when its gets cold, trans fluid expands when hot.
  2. #2 Re: Need help w O2 sensor fail
    Wichita, KS
    ^to add to that, check when its warm, parked on a level surface, and leave it running when you check it.
    ~F~
  1. ZZP fail
    By KeithGTP03 in forum The Rant Forum
    Last Post: 02-10-2011, 02:53 PM
  2. You fail
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 01-06-2011, 04:30 PM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. FAIL
    Last Post: 11-01-2008, 03:45 PM
