Thread: Need help w O2 sensor fail
Results 1 to 13 of 13
  1. #1 Re: Need help w O2 sensor fail
    Nov 2010
    Atlanta Ga
    Exhaust leaks souldnt cause an o2 to read rich. A clogged cat will however cause a rich condition with no power. Running rich or lean for long periods will destroy o2 sensors. Un plug a vacum line and see if your 02 goes lean. If so maybe you really are running rich. If you dont find an oil leak remove a couple of plugs, maybe you are burning oil.
  2. #2 Re: Need help w O2 sensor fail
    Wichita, KS
    ^ya, his plugs looked fine when we had them out for the mods going on. If he was bring oil, we would have seen that for sure.
    Might make sure all the vacuum lines are connected, I know we removed and reinstalled them all, but maybe one came off or something. Never hurts to give it a once over.
    As for your car running hot, you might want to re-purge the air in the coolant system again. sometimes you cant get it all the first time.
    ~F~
  1. ZZP fail
    By KeithGTP03 in forum The Rant Forum
    Last Post: 02-10-2011, 02:53 PM
  2. You fail
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 01-06-2011, 04:30 PM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
  5. FAIL
    Last Post: 11-01-2008, 03:45 PM
