Release pressure from the fuel lines.
Unbolt the fuel rail.
Lift and wiggle slowly on the rail pulling up on the injectors as necessary OR unclip all 6 injectors and pull the rail up seperate from the injectors.
Don't forget new O rings and make sure you clip the new injectors into the rail on the right notch so you don't have any leaks.
